+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 57
Reload Thread: Apsm 1500
  1. #16
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,746
    90 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by av83 View Post
    Yes. And you got a GREAT deal. Just set it with a dmm to 1200-1300 watts, since your electrical will not stay at the 14 volts it requires to make rated.
    Not below 14 volts.
    Really? My maxxsonics 2k sounds worlds better than my old apsm1500.... and it doesnt make my coils stink when the voltage drops even just a lil bit... and its louder.
    how dare you compare AP to that crap offbrand....
    Is it rated for under 14.4 volts?
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC XL D4 12s
    Sub amp - DC 5.0K
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 1 C&D 400mr
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  2. #17
    gumby688's Avatar
    gumby688 is online now Senior VIP Member
    Jul 2012
    Fryeburg,ME
    390
    Re: Apsm 1500
    Quote Originally Posted by quackhead View Post
    I doubt you can expect "clean" power, but if your goal is to satisfy a spl meter, they will work. A S/N ratio of 70db is about 10db lower than I will buy in any amplifier, personally. You seem to have the electrical to support it, which is where I suspect most people who have mechanical troubles with them fail. For $50, it is a ok deal...they are only about $120 new online. No where near the quality of the Amp you have now, but with your choice of equipment, I doubt you will be able to distinguish the sonic differences anyway.
    This is going in a new build for my other car 84 olds delta 88 will prolly step up to a little bigger battery and add a 2nd in the trunk
    Clarion CX-501 HU
    RF Punch 125.2 running
    Infinity 6822CF in rear factory location and
    Infinity 6832CF in front factory
    6 12inch RF HX2's in 13.4 cuft. tuned to 35.5 running off a Popcorn Sounds 4k
    240 Amp American Armature Alt
    100AH C&D in back Optima Yellow top up front
  3. #18
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    2,599
    48 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by rebelfromva View Post
    It doesn't say anywhere in the manual the voltage requirement to make rated, but CEA compliance only requires that it does it at 14.4. Regardless, I think it's a great amp for the money. And I'm only stressing it because it is very often not taken into consideration. Most people with stock alts are lucky to keep there voltage above 13 when driving a 1000+ wrms amp hard enough to get a little loud . Then they get pissed when their subs stink, crying about "dirty power". Some amps will not give you problems when driving it hard at 12 volts, whether they're rated at 12, 13, 14 or not at all. The apsm will, though. Tune it appropriately and its not a problem.
    HU: KDC-X994
    Front stage: Phd FB 6.1PRO KIT, Active
    Sub stage: 1st gen RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: Mmats D300hc
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  4. #19
    Jan 2007
    any wet spot i can find
    3,282
    50 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by gumby688 View Post
    Gotcha, I was referring to the use of drivers with different impedance loads mixed together, as far as SQ...It seems you plan on correcting that issue though.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  5. #20
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    4,209
    Re: Apsm 1500
    I read it a long time ago, but as I understood the CEA amp power spec it only governs the 4 ohm rating, 14.4v, <1% thd.
    So a lot of lower price amps can be CEA-2006 certified and still get away with spec'ing inflated 2/1 ohm ratings.
    Not to say AP does.
    I installed an ap10001d for my newphew and I've been pretty surprised by it.
    edit: yep, no 2/1 ohm regulations: http://www.crutchfield.com/S-MOOh23k...ps/cacomp.html
  6. #21
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Re: Apsm 1500
    lol @av
  7. #22
    snoopdan's Avatar
    snoopdan is offline Banned
    Dec 2005
    Louisville, KY
    20,201
    19
    49 Post(s)
    Re: Apsm 1500
    APSM's are the holy grail of car audio. Cheap as fuck and does rated.
  8. #23
    bgowdy31's Avatar
    bgowdy31 is online now IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,473
    61
    8 Post(s)
    Re: Apsm 1500
    This may sound bad and ill probly get bashed. but i will take the apsm-1500 over any other 1500rms rated amp. just saying. for most 1500s (sundown, skar etc.) i can buy 3 apsm's for of the others......... all 3 of the amps do rated power..... its a no brainer to me. even if i had the $ for the saz or skar 1500 id buy 2 apsms and run 3k and save some $.
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  9. Likes Sleeklsc, Heel4lyfe, TitoThePirate liked this post
  10. #24
    macsdad's Avatar
    macsdad is online now boom-boom
    Jun 2010
    birmingham, Al
    777
    8 Post(s)
    Re: Apsm 1500
    my apsm1500 is the second audiopipe amp i've had, the first one was the apsm1300. the only thing i didn't like about the first one was that the fan would whine for about 30seconds, then everything was fine. the 1500's fan doesn't have that issue. the 1500 replaced a rft1000bdcp that stayed way to warm, i guess my electrical wasn't up to par, even though i upgraded +/- wire to 0/1 knu kca and did the big 3 in 0/1. again, the 1500 doesn't have that issue. to me, you would be hard pressed to tell a difference by ear. it is well worth the money even at full price, let alone 50 bones.
  11. #25
    av83's Avatar
    Mar 2012
    Illinois
    2,599
    48 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by CAT MAN View Post
    lol @av
    Why yooz make laughy sounds at me kittyman???
    HU: KDC-X994
  12. #26
    av83's Avatar
    Mar 2012
    Illinois
    2,599
    48 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by n2audio View Post
    Not to say AP does.
    edit: yep, no 2/1 ohm regulations: Crutchfield.com - CEA-2006 Compliant
    I read that too... And then forgot, lol. Thanks for bringing it up. Explains why my MB quart guts look so much like the brz1700 despite a 300 watt difference in the one ohm rating, too. Also explains how they (AP) are able to rate their amps at <1% distortion @ 1 ohm lol...
    Edit. And yes, I would say that AP spec'ing an apsm as being capable of making 1500@1 with thd that low qualifies a being ” inflated”...
    HU: KDC-X994
  13. #27
    AwesomeStranger's Avatar
    AwesomeStranger is offline Senior VIP Member
    May 2012
    Hickory, NC
    192
    2 Post(s)
    Re: Apsm 1500
    I recently bought a APSM-1500 to run on my two sa-8 v2's and **** I love the price/performance ratio. The amp gets hot quick, I had mine up to 150f (It was flush to the carpet on rear seat) Well a way around that is to make/buy rubber spacers to go under the feet a 1/4-1/2" should be good. Get plenty of air flow under the amp. Mine doesn't see over 120F now. Protect on these are like 175f just fyi, and I use a laser thermometer in my car to read temps.
  14. #28
    macsdad's Avatar
    Jun 2010
    birmingham, Al
    777
    8 Post(s)
    Re: Apsm 1500
    what ohm load are you running? i am thinking on replacing my rft212 with those same 8's. what type box/tune you got? don't mean to thread jack.
  15. #29
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by AwesomeStranger View Post
    That seems really hot still
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  16. #30
    av83's Avatar
    Mar 2012
    Illinois
    2,599
    48 Post(s)
    Re: Apsm 1500
    Quote Originally Posted by SourDeez View Post
    It is. Mine was never hot to the touch. Even at full tilt with a one ohm load for thirty minutes or better...
    HU: KDC-X994
+ Reply to Thread
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-29-2013, 10:20 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  3. wanna see guts of apsm-1500
    By SPLaudio in forum Amplifiers
    Last Post: 04-02-2012, 10:14 AM
  4. 2x12 in L7 dual 4ohm Solo-barics to APSM 1500 wiring diagram?
    By acesrhigh in forum Wiring, Electrical and Installation Help
    Last Post: 03-11-2012, 09:06 PM
  5. Apsm-1500
    By Bettr n' Revrse in forum VMInnovations.com
    Last Post: 03-03-2012, 02:28 AM
