Then I don't understand... Why does it seem like everyone says the distribution block is "necessary" to wiring two amps? Seems like a hassle.. Because you have one main 4ga wire with fuse, then a distribution block, then two splitting 8ga wires each with a fuse on them. The cables and fuse holders and fuses alone will cost upwards of $150!
So with two power cables on the same battery, just have a fuse on each one and I'll be fine?
Register To Reply
Bookmarks
