Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: 4-channel amp produce distortion when bridged???
    PrinceCharming's Avatar
    PrinceCharming is offline PrinceCharming
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    Does a 4-channel amp produce have any noticeable distortion or overheating problems when bridged into two channels at 4ohms? I've been looking at the PPI P900.4 or the to drive my JBL C608GTI MKII components. Yes I know that's a little overpowered but from what I've read these JBL's can take some serious wattage. I just need to know if I should get this or find a good 2-channel, as far as SQ, distortion, and overheating go that is.
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: 4-channel amp produce distortion when bridged???
    A good 4 channel amp shouldn't produce a lot of distortion when bridged. Generally you will get more distortion when you bridge 2 channels, but it shouldn't be noticable. If your not pushing it, the amp shouldn't overheat. It will probably produce more heat when its bridged then it normally would.
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Have you considered going active?
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    Whats the difference between active and passive? I have read some about it but didn't quite understand.
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    active means you power each speaker (each tweeter and each woofer) from dedicated amp channels. so you need 4 amp channels for a 2-way component set. you don't use the passive crossovers with active (by definition it means using active (electronic) crossovers to filter signals to each speaker).
    passive means you use external passive (non-powered) crossovers (using resistors, capacitors, and inductors) to filter the signals. these rob power and produce heat and phase shifts.
    however, i've done much testing with several component sets active (non-bridged) vs. passive (bridged). and more power (bridged and passive) usually won out - especially at higher listening volumes. doubling voltage does wonders for headroom and dynamic range.
    distortion adds (since you have two channels, each with their own THD, driving the speaker), but any distortion common to the amp design can be cancelled at the speaker (if the noise out of phase).
    since bridging doubles voltage which quadruples power - you actually operate at a LOWER THD level when compared to the same output power with non-bridged. this is because bridging takes much less voltage to reach the same power level. (and less voltage = less amplification = less THD)
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  6. Thanks kramer_212 thanked for this post
    Likes West liked this post
  7. #6
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    i think you may have lost the guy with that last sentence
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
  8. Likes keep_hope_alive liked this post
  9. #7
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Awesome responce.
  10. Thanks keep_hope_alive thanked for this post
  11. #8
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by winkychevelle View Post
    eh, that last sentence just explains the math...
    i've worked out the equations by hand... math checks.
  12. #9
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    For high end components it is a good idea to go active, isn't it? As you said, at higher volume levels passive is generally better, is that universal?
  13. #10
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    ok second to last sentence, not the one in parentheses lol
    i got you but some guys will skim that and mis interpret your explanation
    2 alpine pdr-m65
    1 alpine pdr-f50
  14. #11
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    That a great response thanks and it's much simpler than what I tried to read. How bad really does a crossover use up power and create extra heat?
  15. #12
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    my comparison of active vs. passive is using the same amp for both. so take a 50Wx4 amp and run it active or bridge that amp to 200Wx2 and use the passive crossovers. the latter gives you much more power and dynamic range.
    but passive crossovers are annoying and cause many issues. eliminating them lets the amp drive the speaker directly - giving you full control over it.
    i run active and will always run active. you either live with less power (less volume output) or you buy larger amps.
  16. #13
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    I MUST HAVE CONTROL!!! lol THANKS!
  17. #14
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by PrinceCharming View Post
    the heat is just wasted power and lower amp efficiency since the amp produces signals that the crossovers attempts to block with impedance. amplifiers don't like seeing large swings in impedance - and those swings will affect what you hear.
    the impedance plot of a comp set is not flat...
  18. #15
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    i didnt think id ever read you typing that, though to a point i agree, but again a good install can overcome alot of the output problems. which the methods ive used in the past have been learned by studying your installs, so like i said shocker to hear that from you. cant wait to try that fiberglass trick in my new car!! just waiting for the sundown comps to arrive then maybe the mille when the next job starts up
    2 alpine pdr-m65
    1 alpine pdr-f50
  1. Replies: 4
    Last Post: 10-17-2011, 11:20 PM
  2. Replies: 19
    Last Post: 02-13-2011, 02:40 AM
  3. Amp's preamp inputs when bridging two channels
    By grampi in forum Amplifiers
    Last Post: 11-01-2007, 07:59 AM
  4. Can A 2 Channel Amp When Bridged Power A Dual 4 ohm Sub
    By bones justice in forum Wiring, Electrical and Installation Help
    Last Post: 11-15-2006, 08:42 PM
  5. 4 channel amp bridging help
    By Unregistered in forum Amplifiers
    Last Post: 02-18-2002, 01:18 PM
Tags for this Thread
