Results 1 to 10 of 10
Reload Thread: Massive audio Nano Block amps...
    thevic24's Avatar
    thevic24 is offline my silence is deadly...
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    A friend of mine was asking me about the Massive Nano Block amps, mainly the NX2 and N3.
    I have no experience with Massive but have herd lots of good things about them.
    So....I ask you.....any thoughts??
    Silently stalking you through glass....
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Re: Massive audio Nano Block amps...
    solid little amps. i'm starting a build with one. i like Massive Audio for what they are.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    thevic24's Avatar
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Have you used it or herd one yet? And if you have, what was your impression?
    My friends main concern is how the 2ch(NX2) will sound with his comps---is it "bright, flat" ect...
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    One concern people are having about NX amplifiers is that the full range channels appear to be overrated. I have seen a published review with a test showing 65watts of power at 4ohm and 100watts at 2ohm on NX4 channels, a far cry from the 100watt/200watt claim. Granted, not every comp set needs 100watts of power and 2-channel model may be different.
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,424
    141 Post(s)
    1 Thread(s)
    6010 Post(s)
    i have the 800 watt mono block .was in my sons tahoe slamming on a dc lvl 3 15 at 2 ohms ,was even getting a little flex in the doors.i'm impressed ,they do tend to get warm tho
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Quote Originally Posted by zako View Post
    I would like to see someone else do a bench test on the NX4. While it is a magazine that posted those graphs, it's in Russian and so the test procedure might not be clearly explained. It's been a long time since I looked at it. If they tested the amplifier without a load connected it won't make the same power, which could explain the poor performance.
    I was running an NX2 until I went active with a PPI P900.4. I took out not only passive crossovers, but I removed two sets of tweeters, so I really have no clue how different the two amplifiers sound. I did enjoy my NX2 quite a bit for roughly a year, and I've heard no complaints from the person I sold it to.
    I use the N2 wired at 1 Ohm. The subwoofer level on my head unit stays at around 6-8 out of 15, and I don't listen to much music with synthetic bass, but I'm really pleased with that amplifier. I have it under the driver's seat and it gets cold air blown across it during the summer.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    Okinawa, Japan
    37
    5,418
    4 Post(s)
    500 Post(s)
    I ran the NX5 for about 8 months, I'm glad I got rid of it. I had to run a bullet fan beside it just to keep it from going into protect. The A/B side got extremely hot. And I agree that I don't think it does rated for the A/B side. I had them running 2 sets of massive CK6's and at high volumes sounded muffled. I switched out to the Eclipse XA4000 I'm running now and they sound so much cleaner and louder at lower volumes. The Eclipse is rated at 125x4 compared to the NX5 at 120x4. The D side was decent though.
    Current set up: 94 Toyota Chaser (1JZ motor) Kenwood 5907, 3 way active (Alpine DLX-Z30T Tweets, CDT 04's and 06's), Helix P Six DSP/Amp, 4 IDQ12's, MMATS D3000.1
    66 Pontiac GTO, modified stock radio, Crossfire CFA 302, Kicker KS6.2's in the front kicks, Crossfire CFA 452 for the 6x9's I need.
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I have installed a few of them, they will take a beating for sure. Really good power output for how small they are, too.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  9. #9
    Paulspikey's Avatar
    Paulspikey is offline Ghetto Genius
    Mar 2011
    Where Basketball is King
    197
    64 Post(s)
    I had an n3, it was a beast for its size. Loved it.
  10. #10
    zako's Avatar
    Jan 2011
    TX
    1,347
    238 Post(s)
    Quote Originally Posted by trumpet View Post
    I believe they do the tests under the load at very least to check the consumption of current, but I would have to check that. They have tested probably over 100 amplfiers over the years. The interesting thing is that most amplifiers provide at least the rated power, whatever was the methodology.. but this one belongs to the minority that do not. Mistakes and measurement errors could happen, so it would be nice if someone confirmed this.
    In any case, take a look at most 4-channel Class A/B amplifiers that have been confirmed to provide 100 watts per channel at 4ohm.. Something like MB Quart DSC4125 or Boston Acoustics GT-4100. They're _huge_ , about 20 inches of length add or subtract a couple, most likely due to cooling requirements. Even if NX4 and NX5 do the rated power, they don't have sufficient heat sink area IMO. The NX4 series should still be a decent amplifier, just not enough for SPL type of applications. The other day I connected DMM to my front channels which run hybrid imagine speakers.. and got a reading of about 13V with a test tone at normal volume level, which corresponds to about 40watts of power, so a quality 60watt amp would work perfectly for me. But some people buy NX4/NX5 thinking they often have in mind high load applications.. and some of them have not been happy with these amps.
  1. Massive Audio P1000.1 amp
    By reed dollaz in forum General Discussion
    Last Post: 11-11-2007, 10:54 PM
