Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 58 of 58
Reload Thread: Audiopipe APSM-1500 help, seems quiet?
  1. #46
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Audiopipe APSM-1500 help, seems quiet?
    Quote Originally Posted by zorphon View Post
    Nope, ported.
    oh, ok. nv. either way. you are ok.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  2. #47
    Apr 2012
    Los Angeles, CA
    257
    118 Post(s)
    Ok so 40.2 can't damage my subs at all? And not having heard enough systems to judge if it's tight and smooth I don't know if it sounds right or not... O.o.
    Quote Originally Posted by av83 View Post
    Clean and accurate low-frequency reproduction. If you turn it up and it begins to sound, in any way, unlike how it sounded as it did at lower volumes.
    It shouldn't. You have a sealed box, too, right? If so, you are definitely fine.
    That's why I asked.
  3. #48
    zorphon's Avatar
    zorphon is offline Senior VIP Member
    Dec 2011
    US
    226
    98 Post(s)
    I'm going to check for distortion tomorrow. It's too late now to turn it up in my neighborhood, haha. So if I start turning the volume up and the bass starts sounding bad I know it's clipping? I'm fairly sure it didn't sound bad a bit ago when I reset the gain using the -5dB tone.
    And if it was clipping, it definitely isn't clipping it very much. It does sound a LOT cleaner than the Sony amp, perhaps I was clipping my subs with that amp without even knowing. I know with the AP amp it definitely sounds a lot more boomy.
  4. #49
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    I'm positive whomever installed your last amp had the gains set wrong. It should never have reached it's max volume at 50 percent of your hu's volume, lol.
    80prs
  5. #50
    Jan 2012
    Rochester, MN
    517
    215 Post(s)
    Where can I get a -5 DB 50 hz test tone? I also set my gains with the MP3 from realm of excursion, but if I can get louder by using a -5 DB test tone instead of 0 DB, ill try it
  6. #51
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    distortion is not the killer...it can be distorting well before you detect it in the lower octaves...Clipping is what will do u in..a distorted wave (signal) has imperfections....a clip chops the wave top and bottom...more clip -more chop= mechanical failure..
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  7. #52
    zorphon's Avatar
    Dec 2011
    US
    226
    98 Post(s)
    Quote Originally Posted by plantinseeds View Post
    50-59 -5dB.zip
    @quackhead how would I know if it's clipping though? If I was supposed to do 40v AC for 400w RMS and I have it set at 40.2v with a -5db 50hz tone, should I be good?
  8. #53
    Jan 2007
    3,282
    1188 Post(s)
    50-59 -5dB.zip
    you will be just fine. Does the Ap have any clip light or bass knob with a clip light?..I seriously doubt you will distinguish distortion or clipping as it occurs..a light clip (seldom blink) at transient peaks is acceptable, but just glancing at a chart, 40v out should have you well below the amps rated output on a dmm. knowing your head unit's max output voltage can help you visually verify the gain setting is close to where it should be....where is the sweet spot on your HU set?..75% vol is common practice. look, as long as you set your gain on a dmm at 40-41v @ 75% HU volume u should be fine.
  9. #54
    zorphon's Avatar
    Dec 2011
    US
    226
    98 Post(s)
    Quote Originally Posted by quackhead View Post
    I set it at 80% of the HU's volume, 40.2v and it says for the RMS rating of my subs to have 40.0v, at 75% of my HU volume. I also used a -5dB track. Should I redo it at 75%?
  10. #55
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    You're fine. Relax, and enjoy your system.
    80prs
  11. #56
    Jan 2007
    3,282
    1188 Post(s)
    You have already fine tuned your system better than probably 75% of the avg install shops would have done...like av83 said..relax and enjoy it.
  12. #57
    zorphon's Avatar
    Dec 2011
    US
    226
    98 Post(s)
    @av83
    Haha sorry guys I'll relax and enjoy it. I know it's entry-level but I don't have a ton of money and it's my budget system for a little bump in the trunk. Still have more bass than 99% of the other cars on the road .
    Eventually (when I get a car worth more than a grand) I'll have a really nice system, but for now on my part-time job income and saving for tuition, I'm making the best of what I got haha.
    Thanks for your help guys, I'm glad I got a bit more output out of this amp than I originally got, it's just a shame my subs can't let the amp go unchained to its full potential. Someday.
    Thanks again everyone that helped in this thread, I really appreciate it!
  13. Likes av83, quackhead liked this post
  14. #58
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    No need to be snarky with me. I took the advice completely seriously. I don't have access to my vehicle right now because a family member is using it as he just arrived in town and I don't want him to waste his money on a rental. Tonight I'll get my car back and reset the gain with a -5 dB tone, I already have it ready to go to test it. I was just making conversation and asking questions in the meantime, for how do you learn if you do not seek the knowledge?
    Again, I don't know where you got the impression that I didn't take the advice seriously. Just because suggestions were made doesn't mean the knowledge seeking stops there. I will be redoing the Gain later tonight, thanks? I will try out your suggestions, and post back with results.
    There was no snarkiness in my reply. If you took offense to some straightforward advice then I don't know what to tell you.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 05:01 PM
  2. Replies: 204
    Last Post: 07-01-2012, 12:07 AM
  3. Hifonics HFi1000.1D versus Audiopipe APSM-1500
    By zorphon in forum Amplifiers
    Last Post: 06-05-2012, 10:50 PM
  4. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  5. Spent 2k on a sub and amp..but bass seems quiet..help!
    By john.mulvehill in forum General Discussion
    Last Post: 08-11-2010, 01:46 PM
