Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Hifonics HFi1000.1D versus Audiopipe APSM-1500
  1. #16
    zorphon's Avatar
    zorphon is offline Senior VIP Member
    Dec 2011
    US
    226
    98 Post(s)
    Re: Hifonics HFi1000.1D versus Audiopipe APSM-1500
    Quote Originally Posted by av83 View Post
    Any number of things could have caused that dimming. But as long as your alt and battery are in good shape, you have good grounds, and your gains are set right, you will be fine. A/B amps consume more amperage to produce the same wattage as a class D, as well.
    So the Audiopipe APSM-1500 should be fine on my electrical? It shouldn't be any more of a strain than the Sony even though it's more watts, because it's a Class D?
  2. #17
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by zorphon View Post
    It wasn't the amps causing the dimming. There was either a not-so-good ground, or a improper gain setting, or something going else on there.... Running that amp at 4 ohms is not going to draw much at all from your electrical system, as long as it's properly installed and set.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  3. #18
    zorphon's Avatar
    Dec 2011
    US
    226
    98 Post(s)
    Thanks man I needed that bit of reassurance! I'll make to sure to install everything correctly. I'll post some pics and what-not Friday when I'm setting it up to see if the ground is good and what-not. I picked up a DMM as well so I can set my gain properly following http://i76.photobucket.com/albums/j2...7/RMSchart.jpg.
    If I have any questions when installing and stuff I'll let you know but thanks for being a big help so far!
  4. #19
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    No problem. Sounds like you are on the right track, man.
    80prs
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 06:01 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 10:04 AM
  3. Hifonics HFI1000.1D?
    By carpenkl in forum Amplifiers
    Last Post: 04-24-2012, 09:04 PM
  4. Hifonics HFi1000.1d
    By timsm80 in forum Amplifiers
    Last Post: 11-08-2011, 08:25 PM
  5. hifonics hfi1000.1d question
    By xbrandonxx in forum Amplifiers
    Last Post: 06-15-2011, 03:48 PM
