Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 76 to 90 of 205
Reload Thread: Audiopipe APSM-1500 Protection for a few seconds?
  1. #76
    Quick's Avatar
    Quick is offline Senior VIP Member
    May 2012
    Texas
    256
    147 Post(s)
    Re: Audiopipe APSM-1500 Protection for a few seconds?
    Quote Originally Posted by vISUALHype View Post
    Do you have bass boost on your AMP turned up?
    No everyone says it causes clipping.
  2. #77
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,627
    508 Post(s)
    Quote Originally Posted by Quick View Post
    Exactly, what amp alternator do you have? And what Battery?
    References: BigSix,
    This industry is about innovation and setting your own path
  3. #78
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Alright so I'm reporting back with some updated news..
    My volts at the lowest dropped to 13.15, but most of the time went to 13.5 is that really that bad of a drop? I figured it wasn't bad enough for the amp to go into protect.
    After setting the amp with a dmm, I cranked it up to the 75% volume on the HU we used when testing, and the amp went into protect. We added temporary ground to all of the weaker ones that we thought of just to see if it was a weak ground, but still no results. While it was playing, it hit real hard and was shaking the whole inside of my car, was great. Soon after went into protect tho. Ground isn't the problem nor is the voltage drop I don't think. So maybe a faulty amp? I wasn't clipping it because I set it at 41.5 volts and the voltage said to put it at 43.5 with the dmm, so I went safe and put it a little under.
    For the meantime tho, I put the gain about halfway and it hasn't gone into protect yet. Still hits nice but I feel like it's not doing its full potential. Also, I can't crank it up 100% with my HU or it will go into protect, so I have to leave it at 75%. Example is at 21 is perfect on my HU before it starts distorting due to my crap speakers, but I have to keep it at 16 because it will go into protect any higher.
    Everything is either at 0 or off. Treble, bass boost, etc.
  4. #79
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Stock alternator, and a Napa Power 65 Battery. It's Cranking ampage is 550 @ 32 degree's Celsius
  5. #80
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    It would help if you took a picture of your ground and posted it..... That way it can be ruled out. I'm still pretty sure that's the problem.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  6. #81
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by av83 View Post
    How do I post a picture on here? Did that last link work? the one with [IMG] to the left and the right of the link?
  7. #82
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    take a pic with a phone or digital camera, upload the pic to photobucket, right click the image once it's in photobucket and select "copy image location"...... then yes, you right click on "insert image" and paste the copied URL of the pic location.
    80prs
  8. #83
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Audiopipe APSM-1500 Protection for a few seconds?-photo3.jpgAudiopipe APSM-1500 Protection for a few seconds?-photo2.jpgAudiopipe APSM-1500 Protection for a few seconds?-photo1.jpgAudiopipe APSM-1500 Protection for a few seconds?-photo.jpgClick image for larger version
ID:	26533155Click image for larger version
ID:	26533154Click image for larger version
ID:	26533153Click image for larger version
    There is the photos, sorry I posted twice but oh well.
  9. #84
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    is that your amp ground?
    edit: i'm not sure what i'm seeing there, but i know it's not good...... there should be NOTHING inbetween the ring terminal and your ground spot.
    80prs
  10. #85
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    yes, I put a hole through my trunk and fed it down, that's a metal strap that holds my gas tank up, and connects to the metal bumper which is welded to the frame. We had a better bolt but my dad couldn't even break it, and he's pretty dang strong.
  11. #86
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Just drill a small hole in your frame, sand around it well, and use a sheet metal screw and a washer. Do the same thing for your big three grounds to your chassis, too!
    80prs
  12. #87
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Alright going to go work on it, will report back.
  13. Likes av83 liked this post
  14. #88
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Audiopipe APSM-1500 Protection for a few seconds?-photo.jpgAudiopipe APSM-1500 Protection for a few seconds?-photo1.jpgAudiopipe APSM-1500 Protection for a few seconds?-photo3.jpg
    We sanded the hell out of them and still nothing. We added a EXTRA cord to the strut tower, so another ground which should give it more grounding right?? Still protects, and we have it lower gain then the 43.5 hz suggest.
  15. #89
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,818
    1605 Post(s)
    possibly something wrong with the amp at this point? Post internals
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC M2 LVL 5 12s
    Sub amp - 2 DC 5.0Ks
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  16. #90
    Apr 2012
    Los Angeles, CA
    257
    118 Post(s)
    Attachment 26533163Attachment 26533164Attachment 26533165
    Do you got another amp to use? See if you can go to your local car audio store and test out their amps.
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 05:01 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  3. Replies: 7
    Last Post: 04-27-2011, 12:32 AM
  4. Amp cuts off for a few seconds off and on?
    By Justinschmidt1 in forum Amplifiers
    Last Post: 06-20-2010, 04:07 PM
  5. Replies: 4
    Last Post: 05-18-2009, 06:40 PM
