Page 14 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Results 196 to 205 of 205
Reload Thread: Audiopipe APSM-1500 Protection for a few seconds?
  1. #196
    Quick's Avatar
    Quick is offline Senior VIP Member
    May 2012
    Texas
    256
    147 Post(s)
    Re: Audiopipe APSM-1500 Protection for a few seconds?
    I Just redid the connections, it should be great. So, what your saying is I should take a small wire and run it from the positive terminal on the amp, over to the remote terminal and that should turn it on? Wouldn't that give it more volts than it normally would handle? Also I have RCA's idk if that is same thing, sending a signal or w\e.
  2. #197
    slim2fattycake's Avatar
    slim2fattycake is offline rolling right along
    Jun 2008
    In the Stars
    2,192
    158 Post(s)
    use another car and another installer. user error if 2 amps end up not working when both are new and the only thing that is constant is the user and the car.
    SPL-Lab REP
    Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and support? PM me.
  3. #198
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    Quote Originally Posted by Quick View Post
    I don't understand the last part....about the rca's
    It won't hurt the amp to run a jumper from the power wire on the amp to the remote turn on. It should turn on, if not something else is messed up
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  4. #199
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,498
    347 Post(s)
    Did you ever rewire your subs to 2 ohm instead of .5?
    refs: viveet, dvrmstrng,velobard,pickup1,rumblebee2
  5. #200
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    no, it is the same voltage as throughout the car's 12v system.
    the RCA is just the variable low voltage signal output of your HU..This should have no effect on your amp powering up. I assume the RCA's are plugged into the RCA outputs of the HU on one end and the Amplifier RCA inputs on the other?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  6. #201
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Alright so an update.. I wiggled the power wire that is connected at the battery and it budged a itty bit. When I did that my amp powers on now, and doesn't protect.
    Btw yes I did re wire it, away from .5 ohms lol.
    Do you guys think this has been the culprit this whole time? Could that loose connection not transfer enough volts to the amp making it go into protect from low voltage
  7. #202
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Did a voltage test and I'm getting 13.3 volts to my remote and .1 to my power, so it's obviously the connection at the battery. It was working and booming good then cut off and now my amp doesn't turn on no matter how I turn and twist it. I will have to wait til I get home like wednesday or thursday and tighten it down. Will report back then
  8. #203
    Jan 2007
    3,282
    1188 Post(s)
    yes
  9. #204
    daboyfrumdabx's Avatar
    daboyfrumdabx is offline CarAudio.com Elite
    Dec 2009
    Pleasant Mt., PA
    28
    1,199
    39 Post(s)
    Be sure to check the fuse on the power wire also. A friend of mine had an issue the other night with his amp not turning on. A quick meter on the terminals showed like .2V coming from the power wire. Fuse under the hood was blown, or at least partially blown. When you took the old amp out to ship back, did you remove the main fuse or at least tape off the power wires in the trunk?
    *Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
    Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
    Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
  10. #205
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by daboyfrumdabx View Post
    Yes I taped off all the wires so this wouldn't happen. I looked at the fuse, looks perfectly fine.
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 05:01 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  3. Replies: 7
    Last Post: 04-27-2011, 12:32 AM
  4. Amp cuts off for a few seconds off and on?
    By Justinschmidt1 in forum Amplifiers
    Last Post: 06-20-2010, 04:07 PM
  5. Replies: 4
    Last Post: 05-18-2009, 06:40 PM
