Page 12 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 166 to 180 of 205
Reload Thread: Audiopipe APSM-1500 Protection for a few seconds?
  1. #166
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Audiopipe APSM-1500 Protection for a few seconds?
    Quote Originally Posted by Quick View Post
    Alright I'll check on things. SO DISCOURAGING lol.
    ---------- Post added at 10:34 PM ---------- Previous post was at 10:34 PM ----------
    Could It be because I didn't solder the terminals?
    Although soldering is better, no. As long as you can't pull that ring terminal off the wire, you are ok. Make sure all those ring terminals are bolted tight to what ever they are on. Also make sure the power/ground going to the amps terminals are in there good, and snugged down tight.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  2. #167
    Quick's Avatar
    Quick is offline Senior VIP Member
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by av83 View Post
    What would be the most likely the one to check? The alternator positive one?
  3. #168
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    You just gotta check over everything. Make sure all the speaker wires are snug, power and ground connections, fuses, etc.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  4. #169
    madcad95's Avatar
    madcad95 is offline Senior VIP Member
    Dec 2009
    d-town
    334
    95 Post(s)
    When the car is moving sounds like a loose remote , ground or hot at the amp if not make sure the ground bolted to the body is secured and not moving.
    "Originally Posted by Kangaroux" Bridging takes a way a lot of the SQ and it sounds extremely distorted. I believe when you bridge it it switches from a class A/B to a class D, but I"m not positive..
    "Originally Posted by lewshus " The ground shouldnt get any voltage?
    madcad-ninetyfail v.1
  5. #170
    Apr 2012
    Los Angeles, CA
    257
    118 Post(s)
    Since your dad does electrical, I would ask him to teach you some basic about electrical.
  6. #171
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Today I just was at idle slowing down for a stop light and it protected. Everything is tight, be did it with sockets. The ground for sure is goo on the amp. I'll check all the terminals on the amp but should be good. I'm pissed the gain is only up 25% and it protects at about 20-21 volume in my HU. I don't have anything like treble or BB on at all. This never happened to me before why is it now all of the sudden.. I guess because more power..?
  7. #172
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Could it be the +15 on my subwoofer level that is clipping it or something? I'm so confused on what is actually wrong.
  8. #173
    Mar 2011
    27
    3,488
    862 Post(s)
    Naw. If it was doing fine at idle, and it's screwing up when you're driving, there's a loose connection somewhere. Something that's getting jostled around as the car is moving. Does @pro-rabbit have any ideas?
  9. #174
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Can I get some Cliffs on this so I can see if I can help at all?
  10. #175
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
  11. #176
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    Cliffs?
  12. #177
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    This morning going to work the thing cut out on me at a measely 15 HU volume.
    When coming home from work It cut out, so when I got home I stayed idled and played my music at a stop, at 21 HU volume which is where my HU sounds loud and still no distortion. It cut out and protected. Sigh. My system is so bi polar I don't understand what this could be.. A wiring problem?
  13. #178
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    sounds like a wiring issue.
    Check your grounds and power wire connections. If it is going into protect you may also want to check on your subs, it is possible that they have become damaged and causing your amp to go into protect under various conditions.
  14. #179
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    I have a audioque hdc3 12" so how would I be able to tell if it's damaged? It bumps and seems good under the amp goes into protect.
  15. #180
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    I know I ran my amp at .5 ohms at first.. Would that of hurt the sub? It went into protect pretty fast so it's not like the sub was exposed to that for a long period of time.
    Grounds are good, period. I KNOW they are. I'll check the power I guess but I'm pretty sure it's fine.. The gauge of wire I'm using is bigger than the terminals holes, so I had to trim it down to get in into the terminals.
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 05:01 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  3. Replies: 7
    Last Post: 04-27-2011, 12:32 AM
  4. Amp cuts off for a few seconds off and on?
    By Justinschmidt1 in forum Amplifiers
    Last Post: 06-20-2010, 04:07 PM
  5. Replies: 4
    Last Post: 05-18-2009, 06:40 PM
