Page 10 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 136 to 150 of 205
Reload Thread: Audiopipe APSM-1500 Protection for a few seconds?
  1. #136
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Audiopipe APSM-1500 Protection for a few seconds?
    Quote Originally Posted by Quick View Post
    That will double the ohms from 1 to 2 right? Like it doubles 2 to 4 in that example you showed?
    I don't have them wired like that, I have it wired like this, I'll draw a crappy paint drawing.
    Attachment 26533206
    Did you do this yet?
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  2. #137
    Quick's Avatar
    Quick is offline Senior VIP Member
    May 2012
    Texas
    256
    147 Post(s)
    Quote Originally Posted by av83 View Post
    No I'll have to tomorrow. Is that what it's going to do tho? Double it was 1 ohm to 2 ohms?
  3. #138
    Apr 2012
    Los Angeles, CA
    257
    118 Post(s)
    If your subs was Dual 1 Ohms, wiring the subs like that put your subs at 2 ohms, because it's in series.
  4. #139
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,962
    15
    36 Post(s)
    4052 Post(s)
    Yes, this will add the two resistances 1+1=2
  5. #140
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    When you wire two voice coils with identical impedance, in parallel, it gives you a final impedance of half of one of the voice coils. Thats what you did. And you ended up with a .5 ohm load. You need to wire your voice coils in a series, which will give you a final impedance of twice that of one of your voice coils. I only know the basics, and there's certainly much more to it than that, but you get the idea.
    80prs
  6. #141
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    Alright so does it matter where I put the 2 wires coming out that will go into the amp? Can I put them in any negative and positive terminal?
  7. #142
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Yes it matters, lol. Do EXACTLY what the diagram says. Put a short wire leading from the + post of one voice coil to the - post on the other voice coil. This will leave you with one positive post and one negative post open on each voice coil.... hook them up to your amp accordingly. + to +, - to -. use good speaker wire for all of this....
    80prs
  8. #143
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    just realized that you were talking about the fact that the apsm has 4 terminal screws. 2 + and 2 -... lol, my bad. no, that part doesn't matter, I just use the two that are farthest apart.
    Edit: just make sure you're doing it right this time. double check to make sure everything is perfect before hooking it up.
    80prs
  9. #144
    madcad95's Avatar
    madcad95 is offline Senior VIP Member
    Dec 2009
    d-town
    334
    95 Post(s)
    And make sure that they are different coils I seen 1 guy hook the + and - together on 1 coil and run the other + and - of the remaining coil to the amp and that was his idea of series lol.
    "Originally Posted by Kangaroux" Bridging takes a way a lot of the SQ and it sounds extremely distorted. I believe when you bridge it it switches from a class A/B to a class D, but I"m not positive..
    "Originally Posted by lewshus " The ground shouldnt get any voltage?
    madcad-ninetyfail v.1
  10. #145
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by madcad95 View Post
    Lol, I swear I did that about 11 years ago before I started dabbling in car audio. I had a alpine type-r and wanted to run it at 8 ohms off a 300 watt PA amp in a powered sub box off my home system. Ruined it in minutes.... Lmao
    80prs
  11. #146
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Make sure you don't do this @Quick ...
    80prs
  12. #147
    LBC's Avatar
    LBC
    LBC is offline Banned
    May 2012
    Audio Technix
    125
    116 Post(s)
    There were Alpine Type R's 11 years ago? I didn't realize they had been around that long.
  13. #148
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by LBC View Post
    Yep. Looked like this...
    80prs
  14. #149
    KTMrida4life's Avatar
    KTMrida4life is offline CarAudio.com Elite
    Dec 2011
    Durham, NC
    513
    79 Post(s)
    Quote Originally Posted by vISUALHype View Post
    So much fail itt
    Bro Im just going off what I know about my old sony HU. It had a bass level option that went from 0 to 10 (which you always wanted at 10) and then it had a second bass level that was actually a bass boost which could go up to 10 as well and it would clip the crap out of the system.
    My bad. Someone else help the guy.
    1995 Nissan 240SX 5 speed , 37k original miles
    -Headunit: JVC AHD-69
    -Speakers: Polk Audio DB6501 comps
    -Speaker amp: Diamond D104 old school SQ made in USA, running active on the polks ^^
    -Sub: D4 SA12 in a 1.7~cube box tuned to 33
    -Sub amp: Sundown SAZ 3k @ 2 ohms
    -Electrical: 115A Nissan quest alt, Big 3 with 1/0, C&D 75ah under hood, Power 102aH in trunk.
    -Trunk, doors, and rear deck w/ AT 60mil. Doors are sealed. Trunk lid deadened with great stuff + SS Spectrum. Roof also done with SS Spectrum
  15. #150
    Quick's Avatar
    May 2012
    Texas
    256
    147 Post(s)
    So like this?
    What will this make my amp put out? 1000watts @ 2 ohms?
  1. Audiopipe APSM-1500
    By itsblown in forum Amplifier Reviews
    Last Post: 03-10-2014, 05:01 PM
  2. Audiopipe APSM 1500 BNIB
    By Spooney in forum Amplifier Classifieds
    Last Post: 05-23-2012, 09:04 AM
  3. Replies: 7
    Last Post: 04-27-2011, 12:32 AM
  4. Amp cuts off for a few seconds off and on?
    By Justinschmidt1 in forum Amplifiers
    Last Post: 06-20-2010, 04:07 PM
  5. Replies: 4
    Last Post: 05-18-2009, 06:40 PM
