+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Reload Thread: m3a output
  1. #31
    wone's Avatar
    wone is offline CarAudio.com Veteran
    Dec 2009
    2,275
    25 Post(s)
    Re: m3a output
    the m3a is a beast under a small case. i demoed for hours in a show with a stock electrical that thing just kept going with out shutting off, hell my 4ch shut off and the m3a was still going no problem
    REFF'S http://www.caraudio.com/forum/buyer-...-feedback.html
    EBAY REFShttp://feedback.ebay.com/ws/eBayISAP...k&myworld=true
    3 DD 9515h'S
    3 T4000'S
    A COUPLE BATTERIES
    LOTS OF WIRE
    DC 270AMP ALT
    THE BUILD NEVER ENDS
  2. #32
    bgowdy31's Avatar
    bgowdy31 is online now IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,561
    65
    8 Post(s)
    Re: m3a output
    Quote Originally Posted by wone View Post
    yea i kno.... like i said the this dtr is nice i just dont need .5 ohm power
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
  3. #33
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    24
    2,582
    29 Post(s)
    Re: m3a output
    Quote Originally Posted by hispls View Post
    Check this guy's math... claiming that amp is doing 5K or whatever. Right in the screenshot you see 40V * 38A Ohm's law states P=IE so that makes around 1500W. I'm confident that amp can do a bit over 3K, but the guy who made that video needs to lrn math.
    the m3a did 75v and 60a
    2003 JEEP Grand Cherokee
    HU- pioneer 80prs
    Front Stage- Tantric HD comps.
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 4.5^3 32hz
  4. #34
    Dirtrider4eva's Avatar
    Dirtrider4eva is offline √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,188
    16 Post(s)
    Re: m3a output
    Quote Originally Posted by bgowdy31 View Post
    i have this for 2 days. my friend had it before me running .5 with a stock 120a alt w/2 yella tops and maintained 12.5+ full tilt during comps
    and his idle is only 13.5 & rev up is 13.8. and from "taylorfade" on here he clamped them doing 2800+rms with rise to 1.6 ohms @ 12.9v if im not mistakin. so with a stock alt i dont see that to be a power hog. hell my alt is only stock 100a, w/ 2 batts @ 1 ohm im between 12.7 & 13v depending on freq
    ---------- Post added at 10:10 PM ---------- Previous post was at 10:09 PM ----------
    and im pretty sure your alt is probly bigger then both of ours lol
    haha nope, i have a stock 80. plus 55 ah battery and spv 69. off 2.5k from auduioque 1200ds and a us acoustics usx 600f i drop to about 12.8-12.6 full tilt, but i get ridiculous rise to 5 ohms.. so i drop to about 1500 rms cuz theyre strappped. once i build a better box and all, i should see worse. need that 220 amp alt.
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
  5. #35
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,472
    81 Post(s)
    Re: m3a output
    *****. i wish i had one of the m3's lol... i like this dtr1.3400 but i dont need power @ .5 ohm, i need it @ 1 ohm lol
    I might get flamed for this but I wouldn't run the m3 unless it was under 1 ohm..they really come alive when you wire them down. You can get a cheaper amp with the same performance @ 1 ohm.
  6. #36
    dbeez's Avatar
    dbeez is online now CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,820
    52 Post(s)
    Re: m3a output
    Hahaha at 1 ohm the dd amps do some work.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
  7. #37
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,835
    15
    89 Post(s)
    Re: m3a output
    Quote Originally Posted by JEEPWJ4.7 View Post
    Look at the top of the screenshot. The 4500W numbers are under CAD, the 1600W numbers are under M3. Or could be that CAD is abbreviation for Digital Designs and M3 is code word for Cadence.
  8. #38
    splwj47's Avatar
    Aug 2011
    Great White North
    24
    2,582
    29 Post(s)
    Re: m3a output
    Lol did u watch the video?
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 4.5^3 32hz
  9. #39
    hispls's Avatar
    Sep 2009
    4,835
    15
    89 Post(s)
    Re: m3a output
    Yeah like a year ago and pointed it out on there too. Pause it at 1:15 you can see 2 columns for the numbers from each amp. He comes up with some other numbers that he claims are the M3 but look at the top right corner of his piece of paper... What are those numbers from? Why do they say M3 right on top of them?
    I'd be very interested if that M3 can really do 4500W @ 1 ohm dropping input voltage to 13V. Can anyone confirm that can be done?
    Also notice you don't see him actually do the tests AND the Cadence is dropping down a full volt from the DD.
    M3 is a great amp for what it is (under-rated 2400W) but there's no way in hell it's doing the 4500W
  10. #40
    w00tah's Avatar
    w00tah is offline Captain Keffa
    Oct 2006
    Z-Ville, OH
    29
    1,788
    Re: m3a output
    It's funny how other people have clamped it to do well over 3k, but you are fixated on the video. It's okay, you can be mad bro.
    2000 Neon ES- Alpine CDA-7894/Incriminator Audio I65C's/Alpine 3552/Audiopipe AP30001D/Incriminator Audio Death Row 15 dual 1/3.0 ported tuned to 30hz/Knu Konceptz wiring
    OH MECA S2 competitor- 140.1 and counting
    Refs: thegreatestpenn (bought and sold in person) Killa Camry (sold to) TaylorFade (sold to)
  11. #41
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    Re: m3a output
    Quote Originally Posted by w00tah View Post
    Back from the dead thread?
    I clamped a M3a vs a bunch of other amps a couple months ago. It did 4,088w rising to .9 and 13v. Pretty solid. Not gonna get much more out of it than that because that was on caps, I couldn't burp it with more than 15.1v and getting rise much lower than that is pretty tough.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  12. #42
    hispls's Avatar
    Sep 2009
    4,835
    15
    89 Post(s)
    Re: m3a output
    Bring up a thread from 3 months ago to say I'm obsessed or mad about DD amps?
  13. #43
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    Re: m3a output
    AP user sticking up for DD. Lol.
    I actually ran across that vid tonight while doing another search and saw your comment on there. It is a little fishy if you ask me.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  14. #44
    imp4pdabest's Avatar
    imp4pdabest is offline I GOT DA BURNA
    May 2010
    477
    Re: m3a output
    And your point is...? He never said it wouldn't do 3k, he questioned the accuracy of the video. Find something better to do besides bumping threads from 2 months ago.
+ Reply to Thread
  1. Digital Designs M3a actual power output?
    By MONSONwarrior in forum Amplifiers
    Last Post: 06-18-2011, 08:59 AM
  2. cheapest cd player that has sub output
    By kottonmouth in forum General Discussion
    Last Post: 04-11-2007, 02:36 PM
  3. HU's Line Level Output to AMP's Speaker Level Input
    By Unregistered in forum General Discussion
    Last Post: 02-09-2002, 03:51 AM
  4. What do the ohms of an rca output mean?
    By stones in forum General Discussion
    Last Post: 01-23-2002, 04:38 PM
  5. Preamp outputs
    By <lax36> in forum General Discussion
    Last Post: 12-29-2001, 03:10 AM
