If you did get a really killer deal on the Warhorse (under $1k), then you could easily sell it to fund a more affordable set-up.
2009 Hyundai Elantra - Budget Sound in Progress
HU- Kenwood eXcelon KDC-X994
Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
Bought from: Inferno333, select127, treesive, Kangaroux, DonH
Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
Search "Warhorse" in the classifieds here... at least $1.2k before shipping, that's being modest.
Just buy 2 High output alts and 6 big batts and let it bang!
Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
wickedwitt thanked for this post
I would never feed subs twice their rating for a daily setup, you are asking for suicide to those subs. Buy this Fs- Minty American Bass VFL-500.1 pocket the money off selling the warhorse and buy some batts.
Hu: kenwood kdc-x995
Sub: Boston acoustics G5 12 in a quasi 6th order
Amp: Eclipse Xa5000
Front Speakers: Eclipse sc6500
HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
New Car, New Build coming soon... will consist of:
RF 360.3&Apple iPad Mini
Tantric comps
Sundown subs and amps
Mechman HO alt
Deka batts
Knu Conceptz&Shok wire
Audio Technix deadening
The warhorse raped my father and beat my mother
In reality though, it was just DOA and took forever to get fixed. I have my Horse wired up to 6ohms right now with all the the electrical in my sig. Can't really tell you where I'm sitting with the voltage because I can't seem to find the voltmeter i had installed in my car, but it's making power and my vehicle isn't near shutting down/dimming etc. I'll have a better idea for you once I find the darn meter.
I will say this though, with all that shiz you're going to put into that car (i.e. two 18s, x amount of big batteries, big ol box, and the weight of those subs) you're going to want to look into a beefier suspension (heavy duty springs, airride, etc) or your car is going to be sagging like an 80 year old's tatas.
Massive RK6's Front Stage (One set per door) > 07zx650.4
Hertz HSK 165s in the trunk > Alpine 3542
(6) 10" Sundown SA-10s > Kicker Warhorse
Knu Krystal RCAs > lot's o' 0 gauge + Batts > Mechman 270a Alt
1994 Thunderbird
JVC KD-AV7010
Alpine 6x9 3-ways
Pioneer 6x8 3-ways (rear)
JVC CH-X1500 12-disc MP3 Changer
Alpine Type X 12" 2 cubes @ 30hz
MTX 404 runs the inside
MTX 1501d runs the X
Optima G75/25 RT up front
2x Optima G31 YT in the trunk
200a EA HO Alt (1/0 Big 3)
ALL MY WIRE IS WELDING CABLE
DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
OFFICIAL FEEDBACK THREAD
I use a large amp and just powering it up will load down the alternator noticeably. The dangerous thing is that music is dynamic and it's very hard to know when the amp is running at 90% or 20% efficiency, so you could be going along fine, then your song plays the wrong note and you went from drawing 200A to 600A 4 batteries won't hang with that for long.
If you want to run the full 10k, you need 400A of alternator (usually 2 HO) and 6-8 good AGM batteries.
I'm running half of mine atm on 1 275A alt and 3 Deka 9A31s. One less battery and she starts to eat me alive.
Stupid Loud.
Everyone just has a boner for Sundown amps and tries to move everyone off of Kicker eq. Honestly, though, if you aren't going to put serious money into electrical, a 4500 would be better. It would also be a better match for those REs. If you are just going to run two of them, you wouldn't be using half that Warhorse anyways.
Stupid Loud.
Team Flex Issues
4 18" Mayhems
2 bc5500's
Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
It is not good for competitions. It works wonders for daily and 'wow' factor. It's too strenuous on electrical for proper burping and the push/pull make it incompatible with SVC woofers or an odd number of woofers. It also is a higher ohm load than most other 10ks and won't go near the high spectrum of input voltage. Those are probably some of the reasons. As far as 10k amps go, she's dirt cheap.
Stupid Loud.
Bookmarks
