Results 1 to 2 of 2
Reload Thread: 3 subs...mono amp...gain with DMM
    93civEJ1's Avatar
    93civEJ1 is offline Member
    Feb 2008
    IL
    64
    10 Post(s)
    Ok...So if I have 3 8" subs wired up that are 4 ohms each.....this makes the load around 1.34 ohm. If I am wiring this to a 1 ohm stable mono amp and each speaker is rated for 300 watts (amp is 1500rms at 1 ohm)....do I just turn up the gain (voltage) until I see the equivalent voltage for 900 watts? I am guessing this is the way it would work? am I correct?
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    11,052
    897 Post(s)
    Re: 3 subs...mono amp...gain with DMM
    Yes. sqrt(1.34*900) = 34.73V
  1. Setting tweeter amp gains with DMM workaround?
    By andrewsfm in forum Amplifiers
    Last Post: 08-04-2010, 11:25 AM
  2. Adjusting amp gain with dmm
    By ExplicitUrSelf in forum General Discussion
    Last Post: 10-08-2009, 02:01 AM
  3. Replies: 7
    Last Post: 03-28-2009, 06:57 PM
  4. Alpine PDX amps... setting gains with DMM?
    By linksyz in forum Amplifiers
    Last Post: 03-06-2009, 06:09 PM
  5. Setting gains with DMM/ sub control HU
    By Jay2552 in forum Amplifiers
    Last Post: 06-17-2008, 08:42 PM
