Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Reload Thread: What amp should i get without causing headlight dimming?
  1. #31
    MANTI5's Avatar
    MANTI5 is offline CarAudio.com Elite
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Re: What amp should i get without causing headlight dimming?
    Plenty of stock wiring is under 4ga.
    Refs: Mitch86, talon, kramer_212, kushy_dreams, ctmaudi, pro-rabbit, ikoolguy, tat2bass
  2. #32
    Chris_A's Avatar
    Chris_A is offline Junior Member
    Jan 2012
    Glastonbury, CT
    22
    5 Post(s)
    Does anyone know of an efficient and reliable amp that can put out 700-800 watt RMS at 4 ohms? i am looking to power two Rockford Fosgate p2 12"
  3. #33
    Chris_A's Avatar
    Jan 2012
    Glastonbury, CT
    22
    5 Post(s)
    You guys are gonna love this. I purchased two rockford fosgate P2 12 inch subs off of craigslist. I took the subs out of the enclosure to find out they are different subwoofers. One is a P212D2, Dual 2 ohm 250 watts RMS and the other is a P212S4, Single 4 ohm 200 watts RMS. There is nothing i can do with these except buy one more sub that matches either one right? He says he used them together but wouldnt that damage the subs? They are different ratings on ohms and voice coils.
  4. #34
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Back to the question of the amplifier types, buy a modern Class D amplifier for subs and the fronts. These are the most efficient. A Class D amplifier running at 4ohms can easily be more than 80% efficient, and around 75% when running at 2ohms. The Class A/B amps have efficiency of around 60% or so when running at full tilt.
    Of course, if you experience the problems with lights dimming, do the big 3 upgrade, and also run a high quality 4awg or 0awg cable to your distribution block from the battery. A lot of cheaper 4awg kits are a joke.
  5. Thanks Chris_A thanked for this post
  6. #35
    tgraham09's Avatar
    tgraham09 is offline Member
    Mar 2011
    Linesville, PA
    32
    5 Post(s)
    the t1000 will dim the lights for sure
    2001 Toyota Corolla CE
    Alpine idax303 HU
    Speaker amp: Alpine KTP-445
    Front Speakers: Alpine Type-R 5.25's
    Rear Deck: Alpine Type-R 6.5's
    Sub Amp: Rockford Fosgate T1000-1bdCP
    Subs: 2 12" Kicker L5's
  1. What amp should i get?
    By crucifiedsoull in forum Amplifiers
    Last Post: 04-06-2002, 01:37 PM
  2. What Amp Should I Get??
    By QNZIMPORTRIDR in forum Amplifiers
    Last Post: 03-04-2002, 10:38 PM
  3. what amp should i get??
    By Big-Cat in forum Subwoofers
    Last Post: 02-24-2002, 01:54 PM
  4. what amp should i get??
    By ballinplaya in forum Subwoofers
    Last Post: 02-06-2002, 10:16 PM
  5. what amp should i get
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 01-29-2002, 11:13 AM
