Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Massive Audio NX4 - protect mode when ran pretty hard.
  1. #16
    gunz4me2's Avatar
    gunz4me2 is offline Bat Country
    Aug 2009
    Louisiana
    45
    1,650
    93 Post(s)
    Re: Massive Audio NX4 - protect mode when ran pretty hard.
    I owned a pair of Rockford Fosgate Punch 250a2s from the same time frame as the 800a4 until 2006, and I can not for the life of me remember if those had the built-in EQ from the factory. From what you are describing, it sounds like they do which would be a slight bump at 45 Hz and another bump at 12 kHz. That would account for your pounding on the low frequencies and potentially muddy midrange area.
  2. #17
    olds97_lss's Avatar
    olds97_lss is offline Junior Member
    Apr 2010
    Dekalb, IL
    20
    It does have a high pass, low pass and through switch that I have set to through. Along with punch gains that I have turned down. The adjustable crossover appear to be used only when the filter switches are set to lpf.
Tags for this Thread
