Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 110
Reload Thread: what amp to push 2 SA-12s
  1. #91
    Ninesvnsicks's Avatar
    Ninesvnsicks is offline CarAudio.com Elite
    Apr 2011
    Rochester, NY
    897
    Re: what amp to push 2 SA-12s
    Quote Originally Posted by Tony30cl View Post
    lulz. yea. ive got a crap motorcraft battery anf 105a alt with big three. i think its the fusing i have because im running 2/0 to it and i set the gains to 30vAC and runnin at 1 ohm. can i turn this into my ''why does my volts drop bad'' thread?
    lol sure, hmm I think my alt is only 90a according to jeep forum makes me wonder why my voltage situation isn't bad, knock on wood.
    97 Jeep Grand Cherokee Laredo 4.0L Inline 6
    Head Unit: Kenwood KDC-X895
    Speakers: 6.5" Boston Acoustics SC65 (Front), 6.5" MB Quart DKD116 (Rear)
    4ch Amp: Alpine mrv-f303
    Sub Amp: AudioQue AQ2200D
    Sub Woofers: None at the moment
    Wiring: Big 3, Radnor #1 welding cable, Kolossus Fleks Kable 8 Gauge (4 ch)
    RCA's: KnuKonceptz KARSS2.6M and KARSS4.6M
    Batteries: Optima YellowTop (Main), XS Power D5100 (2nd)
  2. #92
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    Quote Originally Posted by Ninesvnsicks View Post
    but really i have a 300a fuse on the 2/0 run then the supplied 100a fuse on the 1/0 stepdown to the amp. could that cause probs? and ill also add it drops to 11.9 revving to 2k
  3. #93
    Apr 2011
    Rochester, NY
    897
    How many amperes do your amps use? I only have a 200a cb on my 1/0 seems to be working fine so far. I would think if u had to small of fuses they would blow.
  4. #94
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    I can take a video of my truck off and the 3500D at .5 ohm...see what the voltage does..I think it gets to 12.1 right now after half a song at full tilt.
  5. #95
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    How many amps do your amps use? I only have a 200a cb on my 1/0 seems to be working fine so far. I would think if u had to small of fuses they would blow.
    umm my 4 chan is 40amps(ran off 8 gauge) and my ap1500 i got no idea. but i can tell its struggleing. but ill get my batts from ryan paid off soon i hope and get the full 1500
  6. #96
    Apr 2011
    Rochester, NY
    897
    My aq1200d had 120a fuses so I'm guessing your ap1500 maybe uses around 120-140a + your 4ch = 160a-180a sounds like your 300a will more than suffice. But yea you need more than just a crappy autocraft I bet you will be ok when u get ur agm.
  7. #97
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    the 4 chan is a seperate power wire. the ap 1500 is on 2/0 with 300 amp fuse and a stepdown with a 100a fuse in it. get it now?
    its only a temp amp unless i get anotherone to strap. thats why the 2/0 is there tho. upgrades my dood.
  8. #98
    Apr 2011
    Rochester, NY
    897
    I wish you guys all lived near me would be nice to have someone actually look at my stuff and be able to talk to them in real life lol.
  9. #99
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    lol i got skype my midget. :3
  10. #100
    Apr 2011
    Rochester, NY
    897
    ah ok well if its not blowing the 100a fuse then sounds like your ok if it was trying to draw more I would think it would blow.
  11. #101
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    i still think something is bagging it. and im only $182 from my two batts lulz
  12. #102
    Apr 2011
    Rochester, NY
    897
    Did you already order a battery?
  13. #103
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    im 82$ away from one and 182 away from both lulz. i gto him to hold em like some cheap lube
  14. #104
    Apr 2011
    Rochester, NY
    897
    lol
  15. #105
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,162
    113 Post(s)
    lol
    get it? cause cheap lube sticks
