go with d4 and get a rubicon 1600
Bggd_GMC thanked for this post
Things to look forward to:
(2) 10" or 12" imperium audio designs subs
set of PHD MF 6.5" comps
Completely seal off and deaden my doors
aquire a 2k amp
aquire a 2 channel amp for front stage
Western Rep.
99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
-Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
-Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
-Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
-Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
-Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
ok thanks!!! ill get the D4s.... my truck is bagged so i still need power for compressors and what not, the Sa-12s fit in my budget and i only had 2 12s sealed, so i just want to be louder then what i was and im sure 1 12 will be way louder then both my 12s.... my 12s sealed got 96 DB on the jl audio app lol
O ok... Well then how much do you wanna spend?
Western Rep.
shoot me with amps and ill consider spending a bit more
SA 1500, AP1500, AQ something, Just run through the classifieds...
Western Rep.
Western Rep.
thanks! whats the max watt/rms you guys would run on these
Western Rep.
im going ported, 30hz
Western Rep.
Get the D4's if you haven't hear that already... And I run mine around ~1300w on my single SA-10 ported ~33hz. That's a lot though. I'd say you're safer around 2000w for the pair. You're not gonna hear any difference between a couple hundred watts at that level anyways. The Massive N4 amp recommend earlier would be terrific. Or an AQ2200.
Massive Audio N4 - excellent condition - with 6 month warranty!
BOOM. Right there. Buy it right now.
2009 Hyundai Elantra - Budget Sound in Progress
HU- Kenwood eXcelon KDC-X994
Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
Bought from: Inferno333, select127, treesive, Kangaroux, DonH
Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
Western Rep.
Bookmarks
