Results 1 to 10 of 10
Reload Thread: 2 amps or 1 big amp! please help
    Roberto Palofox's Avatar
    Roberto Palofox is offline Junior Member
    Aug 2011
    phx , az
    hey im new to this site and i need help. i have 4 12'' hifonics brutus sqaures i bought and i need to know which route i should go on as far as the amp/amps. this is my first system i build from the ground up. the subs are DVC 4 ohm 600watt rms 1200watt peak and they will be in a custom box tuned at 33hz firing up. thanks for the help.
    CHEMMINS's Avatar
    CHEMMINS is offline CarAudio.com Veteran
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Re: 2 amps or 1 big amp! please help
    A single audiopipe 3k would suit ya. Cheap, and good for your ohm load.
    References:
    kmarei, ge_off_me, AudioPipe, slim2fattycake, Louisiana_CRX, ARMed&Bangin, EXTREMECHEVYMAN, Dpc69ss, Psychoacoustics, Shinju, jonny101abc, snoopdan
    BUYING SILVER TOP TRF MOTORS
    Aug 2011
    phx , az
    so how would i wire that up and what ohm will it be at?
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Amplifiers | AP-30001D
    Take 2 subs, put all the + together, and all the - together, and put it in the left channel of the amp....then take the other 2 subs, do the same and put it in the right channel. Done.
    References:
    Aug 2011
    phx , az
    ahahaha that simple huh.... alright bro. i been getting alot of mixed anwsers here locally so i thought id try this forum. alot of people recomended 2 amps, one for each pair wired to 1 ohm.. thanks for your help
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    The amp is 2 boards in 1, hence why you can run 2 ohms bridged or 1 ohm to each side. Easy to do 1 to each side. It will also have the power you need. Plus they are cheap to buy for the power ya get.
    References:
    Aug 2011
    phx , az
    sorry bout all the questions but wiring the way u told me would put me at 1/2 OHM if this diagram is correct im looking at.
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    the ap3k is actually a 2 channel (or more correctly 2 amps in one case) so wiring like mentioned above will put each of the amps inside at a 1 ohm load which is what they are built for.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
  9. #9
    Dirtrider4eva's Avatar
    Dirtrider4eva is offline √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,292
    841 Post(s)
    Looking at a d2 load bro. Yours are d4
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
  10. #10
    Jun 2010
    4,064
    350 Post(s)
    Quote Originally Posted by Dirtrider4eva View Post
    my bet is that he was thinking the 3k is like most sub amps with 2 sets of terminals that are in parallel with each other.
Tags for this Thread
