Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Running an amp at .25 ohms
    Matt A's Avatar
    Matt A is offline Senior VIP Member
    Jan 2009
    Youngstown, Ohio
    205
    Hello,
    I am getting ready for an upcoming competition and currently i am running my 4 hdc3s at 1 ohm off a 3500d.1. I'm not 100% positive what the impedance rise is but I would guess it would double in my enclosure. I was thinking of running the amp at .25 ohms for the competition (never daily). What are your thoughts and what is the maximum time I should burp it? Thank you.
    2005 GMC Envoy
    4 12 Audioque HDC3s (6 cubes tuned to 35 Hz)
    2 Audioque 3500D.1s
    Rockford p1 4x6's in the dash
    Rockford p1 tweeters in the columns
    Rockford p1 components in the front doors
    Rockford p1 3 way coaxials in the rear doors
    Rockford p400.4
    Kenwood DDX 5514
    1 Ohio Generator 250 Amp Alternator, 8 runs of 0 gauge, and 2 XS Power D3100s
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,626
    1589 Post(s)
    Re: Running an amp at .25 ohms
    if the amp can handle it and u can hold an electrical system thats well above 14.4 then it may be possible.....even if it is for a comp u may end up killing off that amp.....
    ---------- Post added at 09:38 AM ---------- Previous post was at 09:38 AM ----------
    i wouldnt run it on less then 15volts
    ahole-ic's Avatar
    ahole-ic is offline Banned
    Jan 2010
    Ivory Tower
    2,936
    289 Post(s)
    The gains won't be worth the risk. If you can hold above 12.6v the amp SHOULD make it, but you never know. You'd be much better off just paying for a test n tune at your local shop, or with thegreatestpenn. You will get MUCH larger gains from finding your freq, tweaking your interior etc, than you will from the mediocre gain .75 ohms less impedence will give you.
    Matt A's Avatar
    Jan 2009
    Youngstown, Ohio
    205
    ic ic so just to make sure I understand... if the box raise doubles at 1 ohm, it does not double when its wired to .25 ohms? the box raise is added not multiplied? and in the winter time my voltage would be a steady 14.7 volts but in the summer months its been at about 14 without music.... im guessing the weather really affects it
    2005 GMC Envoy
    2 Audioque 3500D.1s
    Rockford p400.4
    Kenwood DDX 5514
    MONSONwarrior's Avatar
    MONSONwarrior is offline Constantly Rebuilding... MONSONwarrior is a Supporting Member of the forum!
    May 2010
    Baton Rouge, LA
    1,707
    1 Post(s)
    Quote Originally Posted by Matt A View Post
    Your voltage goes down when the alt is hot, so yeah, weather affects it. I'll charge 15 in the winter and 13.8 in the summer, it *****.
    2002 Chevrolet Trailblazer LT
    Pioneer AVIC-U310BT | Eclipse SC6500 | MB Quart Q4.80
    (2) Fi BTL N2 12 in 4.5 cubes @ 33hz | Cactus K5 | XS D3100 & D3400 | Knu 0 Gauge | Big 3 | 250a Alt
    ahole-ic's Avatar
    Jan 2010
    Ivory Tower
    2,936
    289 Post(s)
    Correct. It is added and not doubled.
    Matt A's Avatar
    Jan 2009
    Youngstown, Ohio
    205
    hmmm.... well i guess the only reason i would jump on the idea is because audioque said it should be fine and i have a volt and clipping indicator right in front of me on the dash... so on the whole no go?
    2005 GMC Envoy
    2 Audioque 3500D.1s
    Rockford p400.4
    Kenwood DDX 5514
    ahole-ic's Avatar
    Jan 2010
    Ivory Tower
    2,936
    289 Post(s)
    It's your stuff. If you want to, go for it. I don't think it will help you much. It's not like you're eeking every tenth out as it is. Controlling impedence rise is really only an option after everything else is tweaked as far as it can go.
  9. #9
    Matt A's Avatar
    Jan 2009
    Youngstown, Ohio
    205
    ic ic.. well i will not do it i guess because i just got the amp repaired so unless it will do wonders i wont do it... for some reason when i metered it last time it was a 145 when the woofers were 2 minutes old.... im not sure if thats a box issue or a wiring issue tho
    2005 GMC Envoy
    2 Audioque 3500D.1s
    Rockford p400.4
    Kenwood DDX 5514
  10. #10
    ahole-ic's Avatar
    Jan 2010
    Ivory Tower
    2,936
    289 Post(s)
    Why is a 145 an issue? Low tuned, large box and not a huge amp. That's about right for the way you have it set up.
  11. #11
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    I wouldn't hesitate to run that amp at .25....just for a burp though, wouldn't do it for daily
    Just watch your voltage
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  12. #12
    Matt A's Avatar
    Jan 2009
    Youngstown, Ohio
    205
    well if you c a lot of other setups online with the similar setup they are well into 150.... in my designs i was thinking a big box and low tuning would be the best of both worlds as far as efficiency with the power i have and the strong low end air flow.... i was expecting 5 db more than i got i guess
    2005 GMC Envoy
    2 Audioque 3500D.1s
    Rockford p400.4
    Kenwood DDX 5514
  13. #13
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by bhsdriller View Post
    First sensible answer in here. Used to run 4 AQ3500's at 1ohm daily and .25ohm for burps. Would gain 2.7dB's when wiring down. You'll have to roll up the volume as they won't pause burp at .25ohm.
    Amp will soft protect at 10.6v, but you should not drop that low on a 3-5 second roll up burp. Also some clipping is fine and normally you'll meter louder. GL at the comp...
  14. #14
    bhsdriller's Avatar
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    Forgot that...roll into the volume
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
  15. #15
    Matt A's Avatar
    Jan 2009
    Youngstown, Ohio
    205
    hmmm so start at 0 volume and cranck it to 3/4 volume... ive never heard of that constraint feature in an amp before but u learn something new every day lol... i mean the woofers will be able to take pretty much any power level i throw at them...its the amp im worried about... but does my electrical look like it can handle 3 second bursts for iasca and db drag spl? ( i doubt it will handle bass race or basss boxing with the electrical i have)
    2005 GMC Envoy
    2 Audioque 3500D.1s
    Rockford p400.4
    Kenwood DDX 5514
