Results 1 to 3 of 3
Reload Thread: Pioneer PRS-X220 compability with Pioneer TS-W304F
    -JJ-'s Avatar
    -JJ- is offline Junior Member
    Feb 2004
    Latvia
    Hi,
    I recently bought Pioneer PRS-X220 and now I was looking for some decent subwoofer for a good price. I found this
    Subwoofer Pioneer TS-W305C Specs:
    Rec. Sealed Box Dims: 1.10 - 1.30 cu.ft.
    Rec. Ported Box Dims: 1.20 - 1.40 cu.ft.
    Free Air Usage: not recommended
    Sensitivity: 89 dB
    Frequency Response: 18-2,500 Hz
    Recommended RMS Power: 400W
    Peak Power Handling: 800W
    Impedance: 4 ohms subwoofer wiring options
    Amplifier - Pioneer PRS-X220 Specs:
    LPF/HPF Network : : 50-120 Hz, -12dB/oct
    Input level/gain control
    PWM regulated MOSFET power supply
    RCA gold-plated input and output terminals enabling Link Top connection for system expansion
    Low load impedance capability (1-8 ohm)
    High Voltage input capability (400 mV - 6.5V)
    High performance balanced isolator circuit
    Reversible endcaps for installation versatility
    MOSFET output section
    DIN power output (W) (DIN45324, +B = 14.4V) 2 x 87 or 1 x 313
    Continuous power output (RMS)
    14.4V
    (20-20kHz/4ohms), 2 x 30W
    (20-20kHz/2ohms), 2 x 60W
    (Bridged 4 ohms), 1 x 120W
    12V
    Frequency response (Hz) 10 - 50,000
    Distortion (%) 0.01
    S/N ratio (dB) 100
    Max. current consumption (A/4ohms) 19.2
    Chassis size (W x H x D mm) 264 x 65 x 240
    What do you think? Will the amplifier handle the power of the subwoofer or should I look for some less powerfull subwoofer with less rms power??
    Best Regards,
    -JJ-
    chronicblazen's Avatar
    chronicblazen is offline Senior VIP Member
    Dec 2003
    orlando fla
    32
    218
    Re: Pioneer PRS-X220 compability with Pioneer TS-W304F
    hey, i got a pair of 12 inch ts w305dvc's in the trunk of my infiniti g20. i have a tiny *** kicker amplifier (kx150.2) borrowed from a friend till i gets mines in the mail (tsunami 1000d), and with so much lilttle power from the lilttle kicker (75x2 rms at 2ohms) them subs kick hard as ****. not competition kinda loud, but ****, for that much power rms, its definatly loud... i cant wait till i get my amp (1000x1 rms at 1ohm)
    ok bottom line, the 305dvc's are the ****, your hearing this from a guy that has never owned jl audio, nor audiobahn, but has heard them, and knows how much they cost.
    for the price of these subs, it gets no betta...
    fazes's Avatar
    fazes is offline Member
    Dec 2003
    Victoria, Canada
    48
    I'd upgrade your amp to at least match the RMS of the subs
