Results 1 to 10 of 10
Reload Thread: Cadence not doing it for me
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    i have a FI Q 18 fully loaded in 5 cubes sealed. i have to pretty much max out the level on the amp and all bass boosts to get the sub to even move like its supposed to. Its running off a 800 amp batcap. so i dont think power is the problem. but the sub def seems to need more and i dont want to clip it. so should i go bigger amp? and what would u suggest? I would like to stay around 250 or less
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,387
    138 Post(s)
    Re: Cadence not doing it for me
    See if you can pick up an Elemental Designs Nine.1 or a AQ 1200. I ran a eD 9.1 on a Fi Q 15, worked great.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - AT - ASE (local) - Batcap - DC - eD - Excessive Amperage - Powermaster - Rainbow
    In Nashville? Me too! Pm me and come hangout!
    Cruzer's Avatar
    Cruzer is offline CarAudio.com Elite
    Dec 2009
    smyrna, tn
    1,818
    aq1200D
    Head Unit: Pioneer 800PRS | Tweets: Vifa BC25SC06-04 1" Textile Dome | Mids: Dayton RS180 | Speaker Amp: Infinity Kappa Four | Sub: Dayton HO 15" | Sub Amp: AQ1200D
    refs:http://www.caraudio.com/forum/buyer-seller-feedback/485413-cruzer-feedback.html
    Legal disclaimer... this is my own personal opinion that I have made from my own personal experience and based on my own personal tastes. At no time have I implied that anyone is wrong in their own opinions and you need to make a decision based on your own opinions.
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    my buddy phatboi runs a audiopipe ap1800d and it slams the ish outta his psi/mt hybrid 12.
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    are those aq1200s underrated or overrated or right on?
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    MI
    12,522
    81 Post(s)
    First of all what Cadence amp? Second of all whats it wired to? Third is it tuned properly via DMM or Oscilloscope?
    Cadence makes some junk and some great stuff. The good stuff does rated and some. The TXA series, ZRS serices, and the Ultrashock series all do rated power and some. I had a Z1200 rated for 1200@1, benches at 1400+@1 with a .05% THD at rated power.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
    Buck's Avatar
    May 2008
    Nashville
    17,387
    138 Post(s)
    Quote Originally Posted by princ3cmo View Post
    I think they are very slightly underrated.
    Mar 2009
    MI
    12,522
    81 Post(s)
    Just saw that you run the Daytona. Is it the DCA-1000 or the DCA1600. Regardless they do rated and some. Either your not wired properly or your tuning is way off as well as your bass boost.
    CA.com FAQ's
    Forum Rules
  9. #9
    Cruzer's Avatar
    Dec 2009
    smyrna, tn
    1,818
    i agree with buck. they do at least rated, if not just a bit more. but they arent highly under rated like say a sundown 1200 that does 1500 or more (supposedly)
    just like AQ rates their subs close to what they can handle(i think). they dont rate the sub for 600 watts and it can handle 1200 daily np
  10. #10
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    31
    2,196
    22 Post(s)
    Quote Originally Posted by whitedragon551 View Post
    this.... i just installed a candence xenith series 400.1 and it's rated for 400rms@2ohm, and 850peak, but i got rated max draggin the truck electrical way down to low 11's. i did notice, it needs a lot of preamp voltage to respond. maxed the gain, and had to use boost to get it up to putting out decent
Tags for this Thread
