Results 1 to 4 of 4
Reload Thread: 130 amp alternator, my next amp?
    HawaiianHaole's Avatar
    HawaiianHaole is offline Senior VIP Member
    Jan 2004
    Delaware
    40
    171
    I currently have a 400W Rockford Amp powering my 4 door speakers and a 400W MTX powering my two cheap Rockford subs. I plan to upgrade the subs in the next two weeks along with the amp to power them.
    I checked my alternator (04 4Runner) and it is rated at 130 amps. If I keep the Rockford 400W powering my 4 door speakers, how large an amp can I get without worrying about needing to replace the battery or alternator. I figured I should, however, upgrade the electrical wiring.
    I was thinking I could safely add 1000W or maybe 1200W but I am not sure. That will be a factor into which subs I decide to go with. I was thinking of getting (2) Rockford Punch HX2 or the RE HC's. But the HC's require a hell of alot of power.
    Would I be able to run 1200 safely and would it be enough to power those beasts?
    I am on a bit of a budget and am planning on $250-$300 for subs and another $300 for an amp.
    I think I will also need to get a cap, some more 0 or 4 guage wiring and an upgraded fuse holder.
    I am very interested in hearing some suggestions about what my system will be able to handle and some model recommendations as well.
    venom107's Avatar
    venom107 is offline The Graveyard Shift
    May 2002
    Independence, Kansas
    32
    607
    It just depends
    Well first off don't waste the money on a cap as you won't need one. It just depends on what kind of amps and what class they are as to how much power it will draw. I have a 100A stock alternator with about 80A worth of fuses on my two amps and it doesn't drain at all. I would definately look into class D amps as they draw less and are much more efficient. US Acoustics sells a 800D and 1000D series that i think would fit your needs. You can check them out on www.thezeb.com You could add another 1000W on there as long as you dont use a high current amp.
    1996 Toyota Camry LE Gold Edition (customized)
    HU- Alpine CDA-9805
    Front-6 1/2 Alpine SPR-17LP
    Rear-6 1/2 Alpine SPR-17LP
    Subs- Audiobahn AW1200Q
    Amps- mids and highs 4 channel alpine 25rms X 4.
    Amps-Sub U.S Acoustics USX800D
    Custom Slot Ported Box
    Tuned to 30 Hz
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,006
    1 Post(s)
    259 Post(s)
    Re: 130 amp alternator, my next amp?
    I think 1200 would be a safe guess. It's entirely possible though, that you could add another 1800 or 2k before you exceed the capability of your alt. with daily listening.
    limitkid7's Avatar
    limitkid7 is offline sell wite
    Oct 2002
    GA
    6,861
    27
    I Got 130/140 I Forget.. I'm Running Bx1500d And Bx6400 And 2 Caps
    White Dodge Charger 3.5L V6
    Diablo Predator
    Alpine d310 TV
    Set of Focal Polyglass 6.5 Comps
    Set of Infinity Perfect 6.5 Comps
    1 JL Audio 300.4
    1 JL Audio 1000.1
    2 9510 mtx subs
  1. Whats wrong with my amp???
    By badazzDD in forum Amplifiers
    Last Post: 09-14-2004, 10:09 PM
  2. Crrent amp Draw? need help As fast as possible :)
    By J13ntv in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2004, 09:48 PM
  3. My Amp setup has changed
    By z00mz00m in forum Amplifiers
    Last Post: 01-19-2004, 12:04 PM
  4. One 4-channel amp OR Two 2-channel ampS?
    By lewix in forum General Discussion
    Last Post: 01-09-2004, 07:49 PM
  5. Capacitor on a 300W amp?
    By Darwin in forum General Discussion
    Last Post: 12-29-2003, 05:24 PM
