Results 1 to 3 of 3
Reload Thread: What's the difference between gain and bass boost on an amp?
    Abunai's Avatar
    Abunai is offline Member
    Apr 2002
    Madison, AL
    28
    88
    budgetSQ's Avatar
    budgetSQ is offline Basshead
    Mar 2002
    CT
    28
    336
    basically
    gain = loudness
    bass boost = added dbs of low frequencies
    if you're lacking boom with the gain 3/4 up, try playing with the bass boost
    will not sound the greatest, and your amp will run hot, but play around with it!
    -(1) Clarion 725
    -(2) Diamond M371i
    -(1) Diamond MacDaddy 12" UNIQUE (long throw) in a ported box
    -(1) 400w 4ch Crunch Drive Bridged
    -(1) 600w 2ch Crunch Drive Bridged
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    40
    1,057
    not quite...
    The gain is to mach the output voltage of your deck to your amp to make it as efficient as possible..Not to be used as a volume..you amp will only put out so much power if you have the gain set too high it will max out b4 the HU does and begin to distort and or clip long before it gets a distorted signal from it..
    SETTING THE GAINS:
    It helps to have a friend with good ears in the car for this.
    Turn the amp gain(s) all the way down..next turn your deck up 2/3 to 3/4 volume and leave it there (as long as the signal is clean not distorted).. now go back to the amp andslowly turn up the gains till your year distortion then then turn the gain back down 1/4 to1/2 turn.. This will make it so your amp will max out approximately at the same time as the deck and get a clean signal doing it..whereever you set the deck is the most you will ever want to turn it up to.
    Bass Boost : boosts a very narrow frquency range usually right around 45hz yes it will make the amp work harder so if you are going to use this function turn it on b4 setting the gains.. If you like the loud resonating bass and your amp was doing it b4 dont bother with it..If your bass was lacking a bit then it may be an option to help out.
    Mike
    Your friendly neighborhood subaru freak!
  1. Replies: 0
    Last Post: 09-24-2007, 03:48 PM
  2. Replies: 3
    Last Post: 09-22-2007, 03:47 PM
  3. What is the difference between SPL and SQ subs?
    By Bulldg2686 in forum Wiring, Electrical and Installation Help
    Last Post: 07-05-2002, 04:18 PM
  4. Replies: 7
    Last Post: 06-05-2002, 04:24 PM
  5. What is the difference between Power and Punch?
    By alexlo in forum Subwoofers
    Last Post: 04-27-2002, 12:26 PM
