Results 1 to 7 of 7
Reload Thread: What amp for my CDT's?
    J13ntv's Avatar
    J13ntv is offline Member
    Jan 2004
    NY
    40
    I need an amp that can run my pair of HD-62ef component speakers from CDT. Theya re rated at 120-130rms I am pretty sure. Anyone know of an amp that will do that at a 4 ohm load but doesn't cost more then say 150? LMK thanks!
    I appreciate the help from everyone who has been helping me in my posts through this board!
    dflock's Avatar
    dflock is offline Member
    Dec 2003
    Rhode Island
    101
    Re: What amp for my CDT's?
    http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
    You can take a step up to the usx-2100 if you want too, but the amp in the link will put out close to 100 watts RMS.
    J13ntv's Avatar
    Jan 2004
    NY
    40
    I don't have to give it at least 130 inorder to be safe so I don't blow them and everything? What happens if you put 100 rms at them but they need more?
    a06144's Avatar
    a06144 Guest
    I just ordered the HD-62ef from theZeb.com and now looking at amps. Here's my list so far: (what max. Sound Quality)
    JL Audio - 300/4 : it has all the features I am looking for plus great sound quality as mentioned here on these boards. The only draw back is that its only 75W x 4 ohms and it doesn't increase in power with lower ohms. But someone said they tested their amp and it was producing around 95W, so I think JL is underrating their amps.
    $379 from (http://www.onlinecarstereo.com/CarAu...roductID=11726)
    PPI PCX480: this is also a great amp from the reviews but is to long (18.5" in length, I would have to place it in the back of the car. I was planning on putting it under the passenger seat for less power cable runs.)
    $259 from
    (http://www.onlinecarstereo.com/CarAu...roductID=11717)
    J13ntv's Avatar
    Jan 2004
    NY
    40
    How are you going to use those though. They only put out 85w maxx at 4 ohms.... Thats not to low for these speakers? I think they are rated between 120-130 rms.. Thanks!
    a06144's Avatar
    a06144 Guest
    Here's the email I received from CDT about how much power you will need for the HD-62ef:
    A good 50-75watt work fine, these are very efficient and good 150 watt even better if gained correct.
    Thanks for considering CDT speakers
    John
    CDT Customer Service
    darrenwang's Avatar
    darrenwang is offline Member
    Dec 2003
    Los Angeles, CA
    37
    150+ watt will sound a little bit better than 70 watt, if you keep the gain low.
    RIght now I bridge 4 channels amp to 2 channels, giving CDT-HD62 200+ RMS watt, and they seem fine. (I keep the gain low) The mid-bass seems much improved by the increased wattage.
    I recommand you to get a clean amp doing 100+ watt per channel. Either Precision Power (cheaper) or Phoenix Gold TI600.2
  1. My Amp setup has changed
    By z00mz00m in forum Amplifiers
    Last Post: 01-19-2004, 11:04 AM
  2. One 4-channel amp OR Two 2-channel ampS?
    By lewix in forum General Discussion
    Last Post: 01-09-2004, 06:49 PM
  3. Capacitor on a 300W amp?
    By Darwin in forum General Discussion
    Last Post: 12-29-2003, 04:24 PM
  4. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  5. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 03:12 AM
