+ Reply to Thread
Page 13 of 50 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 181 to 195 of 737
Reload Thread: Fixing Broken Car Amps
  1. #181
    dynamcpunk's Avatar
    dynamcpunk is offline Senior VIP Member
    Feb 2006
    Lake Elsinore, Ca
    252
    Re: Fixing Broken Car Amps
    The JBL amp powers on but thats about it. I opened it up and you see that some stuff fried. I got from friend who decided to let a shop install it instead of me and they hooked it up wrong.
    System
    Pioneer AVH-P4000-DVD
    Polk DB 5.25 componets
    Polk DB 6.5
    1 10" JBL GTI
    JBL GTO1200.1
    JBL p 360.4
    Wifes system
    Pioneer 5900IB
    10 Jbl GTI
    JBL BP 600.1
  2. #182
    gammey4's Avatar
    gammey4 is online now Senior VIP Member
    May 2004
    La Vergne, TN
    34
    214
    Do you fix us amps? I managed to **** up both my md2d and md43 over the weekend. The md43 wont power on, reads ground at the remote lead and I heard a pop from inside the case. The md2d still comes on but Im getting a weird signal from it, like a ac wave being sent to the subs and it pops hard when it comes on. So hard it pushed one sub to pop the spider loose. I also have a avh-p6600dvd pioneer that wont show a picture when playing a dvd, screen works with everything else and the sound works. Do you work on those also?
  3. #183
    da box king's Avatar
    da box king is offline CarAudio.com Veteran
    Mar 2008
    Portland, MI
    4,688
    Mike, I did not get a chance to come through GR, but a week from today I'll be stopping by and dropping the ppi off, and then the directed and other ppi
    2003 Chevy Trailblazer LT
    (2) 15" AQ HDC3 7.25 cubes tuned to 35 hz
    Rear Fill: Pioneer Premier TS-D602P
    Front doors: ID ctx65
    Kick: ID ctx65cs
    Sub amp: Crossfire VR4000D
    Interior amps: SAX 100.4, PPI pc4400.2 (ACTIVE)
    PM ME: I BUILD BOXES FOR LOCALS OR ANYONE AROUND MICHIGAN
  4. #184
    mike49504's Avatar
    mike49504 is offline Senior VIP Member
    Jul 2010
    Grand Rapids MI
    172
    I work on dvd headunits also yes and i can fix your amps if you would like. Send me a privaate message if you want them repaired and we can work something out.
    DA BOX KING sounds good.
  5. #185
    eggster's Avatar
    eggster is offline Member
    Nov 2007
    Boca Raton Fla
    57
    Good luck with that! I have dabbled and succesfully repaired a few amps, those had obvious signs of distress, I simply changed the row of mosfets which contained the clearly burnt circuit and presto.. That was luck as I have no way of actually diagnosing a not so obvious problem..
    I somehow manage to fix almost anything I put my mind to (except the old hag, had to turn in my lease, too many miles on her)
    I started tinkering as soon as I was old enough to twist a screwdriver (age 4, used to take my toys apart to see what makes them tick, sometimes managed to get them back together, sometimes not.. Dad would revel in it, Mom would beat me I have been fixing all of our appliances since I was 12, not buying an extended warranty? It's a rule of thumb with us..
    I'd like to go to school for this, but I would have to learn math first, plus at 40 years of age, my brain has solidified into an unyielding mass of shitturd, no longer absorbent.. I fall asleep reading anything that isn't pornographic or written on the subject of cars or music.. (much as most of you are probably falling asleep at this moment.. Good God, enough babble here...
    Repairing something that most people would junk? I'll tell you, the feeling associated with a successful repair? (Even though I often end up with extra screws) there is no other feeling like it in the world!
  6. #186
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    14,053
    10 Post(s)
    Quote Originally Posted by eggster View Post
    I started tinkering as soon as I was old enough to twist a screwdriver (age 4, used to take my toys apart to see what makes them tick)
    Even though the amp worked, I wouldn't exactly call that a successful repair. Most of the time if you have mosfets fail they send large amounts of current through their associated resistors and damage them. It may work now but it's probably not going to be all that reliable in the long run...
  7. #187
    eggster's Avatar
    Nov 2007
    Boca Raton Fla
    57
    Mike, how do we proceed? I would like to send you a few amps.. PPI AX400, Mmats D2000 and possibly 3 JBL GTOs.. Just need them repaired, no mods.. High quality replacement parts would be the preference though. How do we act?
    BTW, I want to sell the Hifonics Zues VII.. Interested? If so I'll provide the photobucket link, lots of pics up there, the amp is rough so I will let it go cheap. I've also got a nice pair of PPI A1200.2s in good condition, warranty stickers intact, internals are presumably cherry, unmolested at the very least, both include all the plugs, plumbing for the optional cooling system is installed (done by PPI) and I have a spacer/bridge connector (connects the amps together, with a bit of rigging can be used even with the plumbing left intact)
    I thought you may be interested, something about the comment you made regarding my Zues amp led me to believe as much, not sure why.. Always the opportunist, here I am with an inquiry on amp repair in your thread while attempting to solicit my wares to you Anyway PLMK if you're interested and let me know how we can get the ball rolling with the repairs.. If this works out, I will keep you very busy my friend!!
  8. #188
    eggster's Avatar
    Nov 2007
    Boca Raton Fla
    57
    Quote Originally Posted by bubbagumper6 View Post
    Yup, you're absolutely right about that (conveniently forgot to mention that part of it
  9. #189
    mike49504's Avatar
    Jul 2010
    Grand Rapids MI
    172
    PM sent
  10. #190
    daboyfrumdabx's Avatar
    daboyfrumdabx is offline CarAudio.com Elite
    Dec 2009
    Pleasant Mt., PA
    23
    1,204
    Shipped my amp. He repaired it the same day he received it and shipped back the following day. Received amp today and tested, all is working 100%.
    Thank you.
    *Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
    Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
    Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
  11. #191
    c_nitty's Avatar
    c_nitty is offline Senior VIP Member
    May 2010
    Houston,Tx 77044
    358
    Finished work reviews anyone?
  12. #192
    on1wheel01's Avatar
    on1wheel01 is offline Bang A Lang
    Aug 2008
    Mooresville nc
    2,742
    +1 on that
    REFS
    bought from nismos14,lask48180,wu501,teamsolo,thegreatestpenn, 1phatclipse,lorilee8284,Louisiana_CRX,woofercooker ,97maxima,Bad4Health
    sold to sotogrip,bobby32,rgplayer,mxer657,deathpenalty18,C ahm Rohn
    traded with grimreper912003,5cr4ppy
    1999 Durango 2 Memphis Mojo 15's Audiopipe ap3k
    4 Date Safe 75 ah batts Alpine hu. Lots of wangin
  13. #193
    manish's Avatar
    manish is offline Junior Member
    Dec 2009
    Detroit, Michigan, United States
    hey i have 2 kenwood kac-x1r that i need repair, one turns on but when u crank the volume it shuts off, the other will turn on but goes into short mode. I also have a kenwood kac-x4r which is shot as well. would like all three repaired. I also have a jbl gto14001 and a gto 1200.ii thats need repair. since i live in detroit, i have no problem shipping them after x-mas just send me contact and shipping info. i also have a soundstream ref amp, forgot the model but its a 4 channel that i read is known for going up in smoke. so first i wanna send my kenwoods and go from there. pm me here or send email to ibesp@yahoo.com. heck if possible i might drive up if your turn around is that quick and i can wait for them. also is there any mods available for the x1r?
  14. #194
    cmobley's Avatar
    cmobley is offline Senior VIP Member
    Mar 2008
    Cleveland, Ohio
    325
    Quote Originally Posted by c_nitty View Post
    Wish I could give a review on my amp that he has had since September.
    2005 Dodge Magnum 22" Incubus Paranormals/2 Tone Black N Silver
    Headunit Pioneer AVIC-X920 BT
    Front Custom pods with 8" Selenium/ 8" Eminence/Selenium ST200 Tweeter Front 8" Eminence/Selenium Tweeter Rear Soundstream Tweeters
    Subs(1) Custom Built FI BTL 15" D2
    Sub AmpAQ 3500D
    Comp Amp(2) AQ 4X90 (2) 10" Headrest TVS & PS2
  15. #195
    kevinbvw's Avatar
    kevinbvw is offline Junior Member
    Nov 2010
    walker, mi
    Quote Originally Posted by cmobley View Post
    same boat as you. although i live right up the street from him so im not worried about getting it back. parts are on backorder apparently. hoping to get my amp soon tho!!!
+ Reply to Thread
