mike I have a couple of Orion amps and a PPI amp I need to get repaired. I just blew my Orion 400.2 and I have a 600.4 that produces a whine when activating the internal x-over. The PPI 4400.2 turns on but blows speakers when hooked up.
thanks
thanks
Mike I'll be calling you tomorrow, have atleast 2 amps, but wondering how you are on head units as well.lol
2003 Chevy Trailblazer LT
(2) 15" AQ HDC3 7.25 cubes tuned to 35 hz
Rear Fill: Pioneer Premier TS-D602P
Front doors: ID ctx65
Kick: ID ctx65cs
Sub amp: Crossfire VR4000D
Interior amps: SAX 100.4, PPI pc4400.2 (ACTIVE)
PM ME: I BUILD BOXES FOR LOCALS OR ANYONE AROUND MICHIGAN
whats wrong with the head unit?
Just wanted to let everyone know, I sent Mike a Orion HCCA 250 G4 on Friday 1 week ago and got it back this last Saturday via FedEx. That quick turn-around is probably the exception rather than the rules as he told me he was waiting on parts for some other amps and mine was a simple fix. Thanks Mike.
Absolutely State of the Art!
Mike your PM box is full, wanted to make sure you got the hcca250 and PG xs2500. Said they dropped there on Monday.
03 Silverado SS
Single 12" Tarantula T5 in 2.2^3 tuned to 32hz
Cadence z9000 4ohms bridged pushing around 800wrms
Pioneer Avic D3 Bypassed
Dynomax Exhaust dumped
W4M Performance Tune
Volant CAI
Black 22" Lorenzo 17's
5 Piece Billet Grille
Headlight Highbeam Mod, all 4 at once
Yes got them both ive looked at both of them and found the problems . Ill send you a message right now.
Mike, didn't read through the entire thread but I'd like to know, do you mod amps? I have a few in mind that I would like to get modded.. Would you be able to improve an amps sound quality and or output power?
BTW, I have an asston of amps in need of repair, do you fix Mmats amps? At the moment I have a pair of SS D200IIs that I would like rebuilt and if possible, improved for SQ, I have a first gen Hifonics Zues VII that I would like hotrodded, Mmats D2000.1 that needs repair, PPI AX400 that needs repair. Will be picking up 3 JBL GTOs that also need repair.. Where were you when I had all those PPI amps that needed fixing?
Your thoughts?
I fix all brands of amps so it should be no problem. As far as modding the amps the only mod that could be really done to the ones you have is differnt caps in it to make it have better sound quality . And in my honest opinion As far as the hifonics zeus amp you have i wouldnt mod it if it was my own some people dont like that and it will decrease in value if you try and sell it sometime in the future
When outputs fail in an amplifier it sends out DC voltage to you subs. For example say the rail voltage in the amp is 40 volts and you blow the outputs in the amp in return now you have 40 volts DC comming out of the speaker terminals and that = blown subs. Also there can be other problems with an amp that causes DC voltage on the speaker terminals and not be the outputs 1 example you have bad solder joints on driver cards or the driver card is defective due to leaking caps and such.
good info Mike. The PPI is sitting here staring at me and this Orion. When I contacted Zed on this Orion, Steven said it might be possible to do an upgrade on the Orion which includes a capacitor, IC chipset and power transistor upgrade. It's an Orion Xtreme 400.2, would you recommend an upgrade on this or is it not worth it?
Mike, I have JBL BP1200.1 that has mosfetts and capictors, I think that is what they are I don't know too much about the inner working's of amplifiers. But I want to know about how much it would be to repair it.
System
Pioneer AVH-P4000-DVD
Polk DB 5.25 componets
Polk DB 6.5
1 10" JBL GTI
JBL GTO1200.1
JBL p 360.4
Wifes system
Pioneer 5900IB
10 Jbl GTI
JBL BP 600.1
The orion would be cool to upgrade and i think its worth the money if you want better SQ out of it.
The Jbl amp whats it doing? Stuck in protect,not powering on?
Bookmarks
