I need am amp that will power my 3 hes there 4 ohm so i need an amp that can hold 1 ohm what about the jbl 1200
from what i heard man you should def. look at the jbl 1200.1. In 2ohms it puts out like almost 1400 watts...divide that by three and BOOM
3 four ohm woofers will put a load of 1.33ohms on the amp(theres a formula), A JBL 1200 is rated to handle a minimum of 1ohm, your in good shape with this set up go for it.
if you are porting that sucker ...get a audio control xover then u'll need the filter (sub sonic)
Sony Mobile ES C-90 Audison Bit-One
Audison LRx 3.1 MT
Hertz HSK 130
Mid Bass ?
DB Drive K5 15
Kinetik 1400HC
avital 2200 alarm
dynamat extreme
Bookmarks
