Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Need input on amp
    TopperCNC's Avatar
    TopperCNC is offline Junior Member
    Dec 2003
    Riv-du-Loup, Quebec, Canada
    Need input on amp
    Hi! I am new here, and find the forum really cool. Recently, I got a deal on 2 Audiobahn subs, namely AW1000X (2001 model). They are rated at 600W RMS each, and are DVC 4ohms. Now, I've been lookin for an amp...
    I have checked Audiobahn amps, and have found the A12001DT. What do you think about this one? I will gladly consider other brands if you suggest me some.
    On a side note, I plan to run the subs all in parallel, to produce a 1ohm load. Given that I want to feed each sub enough power, am I right assuming I need 1200Wx1 RMS to run both subs, or will a 600Wx1 RMS will give both subs 600W (hence the 1ohm load?). I am a little confused about this right now, so I'd appreciate a lil' clearing up.
    P.S.: I got a stock 80A alternator. Will it handle that? I am still running a Pioneer 50Wx4 head unit, wired to Pioneer speakers, but no amp on speakers yet.
    Thank you!
    David
    DCHTLH's Avatar
    DCHTLH is offline Junior Member
    Dec 2003
    CC, TX.
    28
    Re: Need input on amp
    You just started a fire, here come the Audiobahn haters! The mono amp you picked is a good choice, I've heard that amp in action, and it definately puts out the juice.
    TopperCNC's Avatar
    Dec 2003
    Thank you for your reply. About Audiobahn haters, well, I take the advice, however, I like to try things myself. I will give them a shot, and at that price, I simply could not pass them up. Here in Canada, we get horrible prices on audio equipment, so when I saw that I immediately sold my crappy old Sherwood 180W 2ch amp... (you get the picture!). Even if many people think Audiobahn ***** or whatever, it will still be a HUGE improvement to me...
    Thanx for pointing out to me that the amp I mentioned handles the job quite well. Now, my concern is: will a 1200Wx1 RMS amp be enough for both subs?
    Thanx!
    David
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    yes it will
    how much u paying for it?
    BumpnRanger's Avatar
    BumpnRanger is offline Member
    Dec 2003
    Richmond, Va
    40
    if it is 1200X1 how you gonna run 2 subs? running both to one channel? im new at somethings.... i know the basics... thanks for replys
    EarDrummin.'s Avatar
    EarDrummin. is offline Is this my Brahma?
    May 2002
    Wanaque, NJ
    36
    1,302
    Quote Originally Posted by BumpnRanger
    Well.. if it's a mono amp there's only one channel you can run the subs on. There's usually 2 speaker outs on a class D mono amp, however. Both speakers will just be recieving the same signal.
    Audi A6
    Alpine 7897
    MBQuart discus
    JBL bp1200.1
    Brahma 15
    AOL: Rav3Cultre
    http://www.sounddomain.com/id/eardrummin
    TopperCNC's Avatar
    Dec 2003
    Hi again and thanks for replies. About the amp, I found some of them on eBay, around $320~$400. Still undecided between the A1300HCT and the A12001DT...
    Both subs are DVC 4ohms, so running them all in parallel would give a 1ohm load, hence the need for a 1ohm stable amp. Since both subs are rated at 600W RMS, I assumed that a 1200W RMS amp would do the job. Correct me if I'm wrong.
    I should be receiving my subs soon, still haven't ordered the amp yet. Will keep you posted about installation. Could take a while though, as I need to pile up some dough... hehe.
    Thanx!
    David
    jtmoney's Avatar
    jtmoney is offline i DiDn'T dO iT!!!
    Jan 2002
    Location, Location.
    36
    896
    6 Post(s)
    Im not too cl;ued up on Audiobahn, but if the A1300HCT (high current? Im guessing) is a class a/b, go for the class D as you only have an 80amp alt, as you said so yourself.
  9. #9
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    41
    2,433
    4 Post(s)
    This is important. Are your speakers Dual 4 ohm coils or dual 2 ohm coils? If they are 4 ohm coils I would wire the subs in series parallel. That way you can get a 4 ohm bridged amp to run them. The reason I would go with a 4 ohm bridged amp is the distortion. Every time you cut the impedance, you raise the THD(total harmonic distortion). If you run the speaker in series parallel, it will give you a four ohm load( if they are 4 ohm coils. If they are 2 ohm coils I would also wire them in series parallel and get the Eclipse 32430 1100 watt dual mono amp. Its 550 watts x 2 with kick but signal to noise ratio good distortion level and great damping factor; I used to own one and it put out a ridiculous amount of power(more than rated) plenty of power for the audiobahns, plus you can get them on ebay for around 200.00-400.00 dollars, they retail at 1000.00 dollars. Thats what I would push them with. If you have questions, ask away.
    Eclipse CD5000
    PPI... DEQ-230
    PPI... PC450 4 channel
    Eclipse DA7232 (2000 watts RMS)
    Focal PS130 Front
    Kicker RS6 6.5" comps
    Kicker R5c 5.25" midrange
  10. #10
    tobz's Avatar
    tobz is offline Independant Thinker
    Nov 2003
    MN
    36
    507
    THD, subwoofer, meh
  11. #11
    TopperCNC's Avatar
    Dec 2003
    Thanx to all who have replied! I have narrowed down my choices to about 4 amps right now... I wanna know what you think.
    - Audiobahn A12001DT
    - Audiobahn A1300HCT
    - HiFonics Brutus BX1500D
    - Orion 1200D
    I believe these amps to all be 1ohm stable, and to provide me with all the power I need. Remember: both subs are Audiobahn AW1000X, rated at 600W RMS each, DVC 4ohms. I intend on wiring them all in parallel (thus 1ohm load).
    Which amp would you choose? Can you suggest others? I know I will probably need to get my alternator rewound, I'll keep the volume down until this gets done. (stock 80A alt on 2002 Hyundai Accent GSi).
    Thanx for replies!
    P.S.: do you recommend a ported/tuned enclosure or a sealed one? I intend on custom building it to fit my trunk nicely, with carpetry and all.
    David
  12. #12
    playa1's Avatar
    playa1 is offline CarAudio.com Elite
    Dec 2003
    Palm springs,Florida
    31
    1,606
    I would get the Orion 1200D and go ported it will be louder
  13. #13
    Dec 2003
    Richmond, Va
    40
    Orion has some great amps. A friend of mine has one that ran at a 1/4 Ohm stable... they are great amps..go with orion
  14. #14
    Chris Cepeda's Avatar
    Chris Cepeda is offline Junior Member
    Dec 2003
    Maryland
    38
    any ppi amps
  15. #15
    TopperCNC's Avatar
    Dec 2003
    Right now, I'm leaning more and more towards the Orion 1200d. I've never heard of PPI amps before... Are they the Precision Power brand? I saw one on eBay, and the S/N ratio was 115dB, rather high to me (the higher the S/N ratio, the better, isn't it?)
    I will further continue my searches and keep you all posted of my finds.
    Thanx!
    David
  1. Whats wrong with my amp???
    By badazzDD in forum Amplifiers
    Last Post: 09-14-2004, 09:09 PM
  2. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  3. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 03:12 AM
  4. Can 8 awg power a 750w amp?
    By danfortner in forum Wiring, Electrical and Installation Help
    Last Post: 11-23-2003, 02:52 PM
  5. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
