Results 1 to 5 of 5
Reload Thread: Cooling Fan
    Rukuzz's Avatar
    Rukuzz is offline Member
    Mar 2002
    McAllen, Tx
    56
    Icon33 Cooling Fan
    Ok audio geniuses I got one for ya!
    I bought a cooling fan for my amp today. I hooked it up to the amp by using the remote power and the amp ground. I got noise feedback to the speakers.
    It seems I have a couple of options. One is that I could tap in directly into the amp power and ground and attach a switch to the fan to manually turn on & off (not an option that's appealing to me).
    Secondly, I could look for a wire that supplys power when I turn the ignition switch. If you've seen the wiring on the tundra it's extremely thin & I don't wanna mess with that unless there's another option.
    Thirdly, I would go into the fuse box and tap into it for power. This is what seems easiest and more appealing to me.
    Does anyone know if there are any drawbacks or anything I could hurt by doing this? Does anyone have any other suggestions?
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    try it all i can say......also try a diff ground for your fan..noise gets in your system via differences in potential.
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    bootleg's Avatar
    bootleg is offline Got Adire?
    Mar 2002
    San Antonio, TX
    443
    You might also try and ground the fan in a different possition than the same one used for the amp.
    Rukuzz's Avatar
    Mar 2002
    McAllen, Tx
    56
    okie
    I think I'll try using a different ground and the amp remote power source. If that doesn't work then I'll tap into the fuse box.
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    keep the fan away from the amp 18" and away from rcas even if it is brushless i have seen these emit noise
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  1. Cooling fan problem!
    By 89montero in forum Car Performance and Repair
    Last Post: 12-10-2006, 03:01 PM
  2. How loud is the cooling fan on Arc 2500xxk?
    By MDXBLUE in forum Amplifiers
    Last Post: 10-23-2006, 02:35 AM
  3. Will I need a cooling fan
    By Dosh142 in forum Enclosure Design & Construction Help
    Last Post: 09-06-2005, 08:32 PM
  4. Heat-Activated External Cooling Fan
    By Aaron407 in forum Wiring, Electrical and Installation Help
    Last Post: 05-12-2004, 10:34 PM
  5. Wiring for a amp cooling fan
    By Ynot in forum Wiring, Electrical and Installation Help
    Last Post: 01-06-2002, 11:13 PM
