Results 1 to 5 of 5
Reload Thread: need help hooking up amp
    southstylestang's Avatar
    southstylestang is offline crazy white boy
    Nov 2003
    north carolina
    27
    904
    i need to know how to hook up a realistic amp. its an old one. im hooking it up to 2 8in speakers. 100x100. the amp is 80x80. it has red wire with fuse taped to a orange wire, black wire, brown wire taped to gray wire, with green wire taped to white wire all together. (b+gy,gn+w) and then (b+gy,gn+w). i need help on what to do from the battery to the head unit to the speakers to the amp.
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    26
    5,170
    Re: need help hooking up amp
    ehh u run ur RCA's from the HU to the amp. and a Remote turn on wire from ur HU to the amp. Power wire gets run from ur battery to ur amp. Ground wire gets run from any peice of metal on ur car to the amp. and thats it.
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
    cwzilly's Avatar
    cwzilly is offline Hates distortion
    Oct 2003
    Horsham, PA
    250
    Quote Originally Posted by southstylestang
    Brown wire taped to grey wire, ect....So you mean like scotch tape???
    mmmm, wires arn't suppose to tape together, but maybe i'm mistaken you????
    Like he said above:
    • Power wire from amp to fuse holder to battery
    • turn on lead from amp to reciever
    • ground wire from amp to bare metal on the car
    • RCA plugs from amp to reciever
    • speacker wire from amp to speacker
    I'm confused on your grey, and brown wire together, or maybe i mistunderstood you. I guess you should get new wires?????
    Calling us NO GOOD; you are the social enemy, us people change day to day...
    Nov 2003
    north carolina
    27
    904
    the brown and gray are taped together at the bottom like you would put a posative and negative to gether so you know which ones hook with other wires i dont mean the ends of the are together. but im still confuse on which wires are which. whats the orange one for?
    end of wire ~===brown wire=====[tape]===amp
    end of wire ~===black wire=====[tape]===amp thats what i mean by taped together sorry for the misunderstanding. i hope that kinda helps thanks
    Nov 2003
    north carolina
    27
    904
    end of wire ~===gray wire=====[tape]===amp thats what i mean by taped together sorry for the misunderstanding. i hope that kinda helps thanks
  1. Whats wrong with my amp???
    By badazzDD in forum Amplifiers
    Last Post: 09-14-2004, 09:09 PM
  2. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
  3. sub amp going into protection when low notes hit
    By B|2imstone in forum Amplifiers
    Last Post: 12-08-2003, 03:12 AM
  4. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
  5. hooking a car amp up in my dorm room
    By Qball in forum General Discussion
    Last Post: 09-09-2003, 10:11 PM
