Results 1 to 3 of 3
Reload Thread: new guy needs amp selection help
    nova's Avatar
    nova is offline Junior Member
    Sep 2003
    MS
    Icon7 new guy needs amp selection help
    Ok, I'm almost brand new to the car audio scene. About the only thing I have going for me is friends who know a little and a little electronics background.
    I want some subs for my '94 Camaro and after listening to as many different subs as I could find in my area (arguably not all that many) I decided on 3 JL Audio 10W3V2 with dual 6 ohm voice coils which can handle 300W RMS each.
    I plan on using a sealed box and wiring for a 4 ohm load.
    Now, my real question is to the wattage of amp I need.
    Do I just need an amp that can deliver 300W at 4 ohms or do I need an amp that can deliver 900W (300W/sub X 3 subs) at 4 ohms?
    I know its probably a stupid newbie question but I've read everything I can get my hands on and can't find anything resembling an answer.
    What little electronics knowledge I have says that I would need the 900W since voltage and current should be equal between equal resistance paths of a parallel circuit. Since the current would essentially be divided by 3 and Amps X Volts = Watts it seems like you would need 3X the wattage. Since I'm new to car audio I want to make sure I'm thinking in the right context though.
    Also any advice on a good amp would be welcome.
    Thanks in advance for any advice you could give.
    nova's Avatar
    Sep 2003
    MS
    Re: new guy needs amp selection help
    OK, so I was right thinking I would need a 900W amp.
    I'm probably going to get an amp that is around 900W @ 4 ohms, with my searches it seems like 4 ohm stable amps are a little easier to acquire than 1 ohm stable amps.
    Although I don't know much about amps that soundstream looks pretty good, especially for that price.
    Now another question I have is since that amp puts out 1000W and the total max wattage of the subs is 900W, how safe is that going to be? Its not going to put excessive wear on them or blow them is it?
    nova's Avatar
    Sep 2003
    MS
    Cool, thanks a lot. That soundstream sounds like a really good deal now.
  1. im new. how to install 4-CH amp?
    By Forty-Ouncer in forum Wiring, Electrical and Installation Help
    Last Post: 06-28-2004, 08:35 AM
  2. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
  3. amp for 2 he2 dvc 4ohms ? what amp ?
    By El_dorado in forum Amplifiers
    Last Post: 09-21-2003, 06:30 PM
  4. Got my new amp today
    By dbhittin in forum Amplifiers
    Last Post: 09-15-2003, 04:16 PM
  5. Can I wire a MTX Thunder6000 12" To my amp ?
    By Warrior in forum Wiring, Electrical and Installation Help
    Last Post: 09-11-2003, 12:22 AM
