Results 1 to 15 of 15
Reload Thread: Help; amp goes into protect mode when input @ 50%
    Jan 2009
    New Jersey
    611
    I have the input for both sets of speakers at half way up (hu @ 100% volume)
    The infinity speakers can go up to 3/4 input until they distort, but when I turn the JL Audios input up past 1/2, the amp shuts off? (protective mode?)
    I read the trouble shooting manual that came with the amp, and it said it may be because of a short in the wiring.
    What is a short? And what could possibly be the problem? (if it even is a problem...shouldn't the JL audios imput be 2x higher than the infinities though?)
    btw, I soldered the terminals onto the speakers (because they were slightly too big) but they're tight to the pull now. I also put bare wire into the amp itself because the spade terminals I got didnt fit in it.
    Amp puts out 75 watts rms
    JL's handle 80 RMS
    Infinities handle 60 RMS
    Amp is: EA 4100 Eclipse
    headless's Avatar
    headless is offline CarAudio.com Elite
    Feb 2006
    Florida (Tallahassee)
    1,292
    Re: Help; amp goes into protect mode when input @ 50%
    If your HU is at 100% volume, you shouldn't really need gain on your amplifier to be up very high at all. The gain pot on your amplifier is not a volume nob; just because it's set 'half way' does not mean the amplifier is generating 'half power'. read www.bcae1.com and return afterwards
    http://www.bcae1.com/amplfier.htm
    Eclipse CD7000 - RioCar Empeg 3
    Rainbow Powerline CS 275.27 / Arc Audio 4150 XXK (Woofers) - Arc Audio 2100 XXK (Tweeters)
    Rainbow Vanadium 12 x2 / Arc Audio 1500 XXK
    Quote Originally Posted by TEAM HAMMER
    Your so full of Crap! The last place you want a Midbass or Sub is in front of you Retard Whens the last time you seen a 12in+ sub up front?
    Quote Originally Posted by bdawson72
    Technically, bigger wire has more resistance.
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    still shouldnt turn off just past 1/2 way...
    funny thing.. im having the same problem
    Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle (picked up box) mlstrass (box design) Mazzasec (bought 18" RD Alpha from him) SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic on steave meade forum. NJTStang11- picked up 18" SSX and box from him krispy cream SCAMMED ME $200!!!
    2 Pistol Shrimps in a 4.0 cu^ft box tuned to 32 hz for the WIN !!
    "You can't compare, don't stare, cause I got the ultimate Mary Jane"
    bradknob's Avatar
    bradknob is offline Senior VIP Member
    Dec 2008
    new orleans
    231
    2 Post(s)
    i know some of the infinitys are 2 ohms (mine are) but i dont know which model u have. So there could be an impedence prob. would need some more specifics.
    ::SETUP::
    ::Pioneer p880prs::
    ::ESX Q120.4 (beast)::
    ::ID OEM's Deadened sealed::
    ::3" Tang Band Bamboo cone::
    ::1" Tang Band ceramic dome tweets::
    ::Refrences::
    Bought:: duece212, na_rsx
    sold:: TheLow,BallinbyNature, pieper88
    Trade::FasFocus
    Quote Originally Posted by kcdc30 View Post
    tune it to 12 hz and lay your ***** on the subs cone...........i really enjoy it, personally.
    SocialStealth's Avatar
    SocialStealth is offline Banned
    Jan 2009
    New Jersey
    611
    I read that link, and according to their calculator, my amp gains should be at about 3.7 for the infinity speakers and 2.3 for the JL audios. Thats assuming my hu is putting out its rated preamp 2 volts.
    The lowest gain setting is 8 volts and the highest is 0.2 volts.
    The JL's are set in the middle and the infinities are 1 notch below the middle.
    I'm no math wiz, but thats no wheres near 3.7 or 2.3
    The built in clipping light on the amp does not turn on when at higher volumes, the amp just shuts off.
    The infinities are 2 ohms, and the only problem they would present is causing the amp to run hotter.
    Even so, the problem I'm having is with the JL audio's (4ohms)
    Shinju's Avatar
    Shinju is offline CarAudio.com Veteran
    Aug 2008
    Seattle
    4,823
    117 Post(s)
    sounds like a low voltage issue.
    List of Ref's Just ask, Shinju on all Car Audio Forums!
    Flawless Ebay Feedback User: Shadox2k2
    Jan 2009
    New Jersey
    611
    Quote Originally Posted by Shinju View Post
    Whats that mean?
    What should I do?
    SicAudio's Avatar
    SicAudio is offline did you fart dude?
    Apr 2009
    melting HO alts...
    47
    6,201
    2 Post(s)
    what guage wire is running to the amps from the battery? you need to get at least 12+ volts at the amp positive terminal.
  9. #9
    Jan 2009
    New Jersey
    611
    Quote Originally Posted by SicAudio View Post
    4g wire from the bat to amp w/ 4g ground. 12g speaker wire to all the speakers.
    I've never performed the 'big 3', so I'm assuming its 8g stock wire in there.
    would performing the big 3 solve a voltage issue?
  10. #10
    Grinder1989's Avatar
    Grinder1989 is offline Sundown Audio Dealer
    Jan 2007
    Akron, OH
    5,730
    Quote Originally Posted by headless View Post
    Quoted directly from your second link.
    You can not make a blanket statement such as 'gain controls are not volume controls'.
    Also, you sir, are incorrect. Maybe with his headunit, the gain needs to be close to all the way up. You don't know, so don't make uneducated guesses.
    OP, check your ground and make sure it's good.
    North Coast Improvements, Mobile Audio Division. Sundown Audio Dealer Akron, OH. Need BNIB audio? PM me for details.
    By: N.G.U Graphics
  11. #11
    headless's Avatar
    Feb 2006
    1,292
    Grinder, you're saying the EA4100 is built so that the gain is actually a volume control ? It gives 0 output from the amplifier, even with any amount of input when gain is set to it's lowest setting?
  12. #12
    Jan 2007
    Akron, OH
    5,730
    No. I'm saying your logic is wrong. I was not talking about any amp in particular, just in general. The easiest way to look at gain is that it controls how fast your speakers get loud. You can turn the gain all the way up on your amp and just keep the volume low on the headunit.....That's the easiest way to get max power out of your amp but you lose the benefit of high input voltage. Its harder to set the gain with your headunit all the way up (or 3/4 of the way up) because without an O scope, its hard to tell if you're clipping or not. That's how people ruin their equipment. As far as gain goes with this situation, it's irrelevant. OP has a low voltage problem because of a bad ground (more than likely)
    By: N.G.U Graphics
  13. #13
    headless's Avatar
    Feb 2006
    1,292
    Or, as you said, he could be clipping out his HU which is causing the amp to go into protect - likely, even, since the deck is at 100% output and i've not seen many decks that don't clip at 0db output. Even nice eclipse's will clip out ~10% under max volume. Setting your HU to max volume for setting gains kinda defies the purpose of setting gains at all, unless your HU NEVER clips at 100% volume. I suspect his panasonic isn't going to be that way.
    I don't think it's a bad ground at all; i think it's just clipping and the amp is trying to save itself. I suspect re-setting gain w/ the HU at a reasonable volume will help - but of course, i could be wrong *shrugs*. So could any of us we're getting barebones information from an internet post and we're all guessing.
  14. #14
    Jan 2007
    Akron, OH
    5,730
    Or, as you said, he could be clipping out his HU which is causing the amp to go into protect - likely, even, since the deck is at 100% output and i've not seen many decks that don't clip at 0db output. Even nice eclipse's will clip out ~10% under max volume. I don't think it's a bad ground at all; i think it's just clipping and the amp is trying to save itself.
    I've never seen an amp that shuts down because of clipping, ever. Maybe the eclipse does, but I wouldn't know. But I've seen many, many, many amps driven into severe clipping and not shut down. Indeed he may be clipping his amp by turning it all the way up, but his deck might be putting out low voltage even at high volume.....there's too many variables. I still think a bad ground is the culprit and I think it should be addressed before getting his stuff not to clip.
    By: N.G.U Graphics
  15. #15
    Jan 2009
    New Jersey
    611
    Well I tried setting the amp's gains @ 3/4 hu volume and i found:
    The amp did not shut off and go into protect mode
    The amp did not show clipping (it has a clipping led on it)
    Even at 100% gain it did not clip, however I think I could hear distortion after 75% gain so I put the gain at 70%
    So most likely, I think the hu was clipping @ 4/4 volume and sending the amp into protect mode.
    My next issue is...
    I have speakers in my front doors, rear deck; and I want to add speakers into the rear doors.
    The front speakers are 2 ohm the deck speakers are 4 ohm.
    The amp is made for 4 ohm speakers; and runs a little hotter with 2 ohm speakers.
    So I want to get 2 ohm rear door speakers and put their wires into the same amp terminal as the other front door 2 ohm speakers; right?
    That will create a 4 ohm load; but how much power will it send to the speakers?
    I figured I would put another pair of infinity references (handles 60 rms) into the rear doors.
    The amp can send 75 rms
    Will the speakers get about 37 rms each?
    Or because they're 2 ohms, will they draw more than 37 rms, even though they add up to be 4 ohm?
