Results 1 to 2 of 2
Reload Thread: Pleze Help does this amp go good for these subs?
    KB777's Avatar
    KB777 is offline Senior VIP Member
    Jan 2009
    home
    167
    Icon32 Pleze Help does this amp go good for these subs?
    This is the amps stats
    The LA370 is a 2 Channel 500 Watt MOSFET Amplifier.PRODUCT FEATURES: 2 x 200 Watts RMS @ 4 Ohms; 2 x 320 Watts RMS @ 2 Ohms; 2 x 1200 Watts Max Output; 1 x 2400 Watts Bridge Mode; Polished Chrome Finish w/Plexiglass Panel; Soft Turn On/Off Circuit; Variable Gain Control; Remote Turn On/Off; Hi/Low Level Inputs; Power On LED Indicator; Fully Adjustable Electronic Cross Over Network; Remote Control Bass Boost (0-18dB @ 60Hz); 2 Ohm Stereo Stable; Bridgeable Into 4 Ohms; MOSFET PWM Power Supplies; LED Protection Indicator; Frequency Response: 10-30 kHz; Power Supply Voltage: 14.4 VDC/NRG GD (10.5-16V); Maximum Current Draw: 50A; Dimensions: 11.5W'' x 2''H x 19''L.
    And this is the subs stats (there will be 2 of them)
    500 Watts Max / 250 Watts Rms
    Poly Cone / 1.5" kapton Voice Coil
    80 oz Magnet Structure
    Mounting Depth 4.92"
    20Hz - 2.5kHz
    Brown Injected Polypropylene Cone
    Specially Treated Black Rubber Edge Suspension
    Bumped & Vented Motor Structure
    1.5'' High Temperature Kapton Voice Coil
    80 oz. Heavy Magnet Structure
    250W RMS/500W Peak
    Frequency Response: 25Hz-1KHz
    SPL (1W/1M): 89dB
    4 Ohm Impedance
    Overall Diameter: 10.83''
    Mounting Depth: 4.92''
    Will this amp do good? I dont want to excede the rms for the subs cause they are a cheep brand but its all i can afford right now
    Obama is just a puppet he is not in charge. Go to this link and watch the video (The Obama Deception) and find out whats going on behind closed doors. Dont take my word for it watch it and decide yourself.
    http://megavideo.com/?c=search&s=The+Obama+Deception
    These things are going on now.
    undeadxsunshine's Avatar
    undeadxsunshine is offline what it is
    Nov 2008
    York, PA
    1,264
    3 Post(s)
    Re: Pleze Help does this amp go good for these subs?
    Should work fine, you'll be underpowering the subs a bit. I don't know how good Legacy amps are though.
    2001 Mazda Tribute (Previous)
    HU: Alpine CDA-9886
    Front Stage: Hertz HSK 165
    Front Stage Amp: Arc Audio KS 300.4
    Sub: 2 Sundown SA-12s in 4 ft^3 @ 34hz
    Sub Amp: Sundown SAZ 2000D
    Refs: ampjunkielikeme, clbolt, SPL-Master, Twisted_0912, Qbenjamin, plyer3, tr10av, Lucid15, Alter Ego Trip, Topless Stang, Gville, wgsj_fortvalley, PioneerSPL1990, l4yfr4me
    Feedback Thread: http://www.caraudio.com/forum/showthread.php?p=5791608#post5791608
