Results 1 to 5 of 5
Reload Thread: What should I tune my amp to?
    blazian87's Avatar
    blazian87 is offline CarAudio.com Elite
    Mar 2007
    Los Angeles, CA
    1,260
    7 Post(s)
    483 Post(s)
    I have a Rockford Fosgate 800a2 and I got 2 12" Diamond Audio D6's in a sealed box. They sound pretty good but doesn't get low enough for me like my old setup: 2 cubic ported box running one 12" . I don't really want to go ported because I listen to a range of music but yes i do listen to rap and R&B on a daily basis though. I just don't know what to tune my amp to. It's currently at 80hz and my gains are about half way. Any suggestions on making it sound better for certain types of music?
    groundpound4200's Avatar
    groundpound4200 is offline Da fuq did I just read?
    Nov 2007
    Mankato, MN
    32
    5,250
    359 Post(s)
    Re: What should I tune my amp to?
    tune it to 100000000. If that doesnt work I would build a nice ported box and tune in the low 30s.
    2007 Honda Pilot 2008 Nissan Maxima
    2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
    2 Sundown Nightshade V.2s 2 10" Atomic APX
    Sundown SAX-125.2 x 2 Sundown SAX-100.4
    Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
    RIP Taylor aka NewAgeKing, you are missed!
    blazian87's Avatar
    Mar 2007
    Los Angeles, CA
    1,260
    7 Post(s)
    483 Post(s)
    haha is it me or does everyone in this forum only have ported? but I can totally understand why tho. Can anybody give me a number I can work with though? Is 80 just right?
    Turns out my gains are way too low for how much power these subs needs. I just thought that since it rattles so much that I should keep it down to make it sound clean. I already used some leftover sound deadening (b-quiet) from my previous car but there still is alot more to cover and 1 layer isn't quite enough. and I'm upgrading my headunit into the CDA-9886 this weekend so I'll be hoping to play around with the eq settings to make my comps come alive.
    Undisputed King's Avatar
    Undisputed King is offline Senior VIP Member
    Nov 2008
    CenCal
    179
    2 Post(s)
    A better question would be "What do I set my LPF and HPF to?" Your HPF should be set to like 25Hz or so. And your LPF to around 80Hz. Because the HPF lets frequencies higher than your setting play on your sub, while the LPF lets frequencies below your setting play on your subs. HPF is the lower limit, and the LPF is the upper limit. Make sure you dont have your HPF to like 50 hz, then that would be the problem your not playing low. The above statements are a good starting point for a sub amp. Your component amp settings should be set to HPF, and make it like 80Hz and above.
    2000 Silverado Ext Cab Z71
    Exterior:
    10" Whiplash lift, 18" blk Raceline Renegade wheels, 35x13.5 ATZ's, Super 40
    Sound:
    Panasonic HU, RaamMat, 15" AQ HDC3 3.6 @ 38Hz designed and built by me , Crunch GP3000D, PG RSD Components, JBL Px300.4, Kicker 1/0 & 4 AWG, 2xG32 Dekka Power
    2000 Yamaha R1
    Leo Vince slip on, Hot Cams, +3T rear sprocket, Electric Blue pearl, many tickets
    gunz4me's Avatar
    gunz4me is offline Goodbye!
    Jul 2008
    Louisiana
    45
    2,218
    Do you really think he needs a subsonic filter with a sealed enclosure?
    Goodbye pudknockers.
