Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 131 of 131
Reload Thread: Saz-3500
  1. #121
    denim's Avatar
    denim is online now SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,086
    15
    64 Post(s)
    902 Post(s)
    Re: Saz-3500
    Nice pictures.
    CarAudio.com mod(original)
  2. #122
    mcsoul's Avatar
    mcsoul is offline such is life
    Mar 2008
    dfw
    4,427
    Re: Saz-3500
    Someone describe what they would consider the minimum electrical
    system someone should use for this beautiful monster.
    ________________________
    Car: 2004 Nissan Altima 3.5 manual
    Head unit: Alpine CDA-9815 (running active)
    Midbass: Morel HU-621 Hybrid Uniflow 8 ohms
    Mid Amp: Audison lrx 4.300 bridged 2x140w @ 8 ohms
    Doors: 24ft Damplifier Pro, Second Skin D-flex pads, eggcrate foam, sealed up.
    Tweeter: SEAS 27TFFNC
    High Amp: Audison Lrx-2.150
    Subs: Two RE SE 12 d4's
    Box: 4 cubes net at 30hz
    Sub Amp: Sound Stream Van Gough 1600.2
    Electrical: Knu Flex 1/0, Batcap 2000 in back
    Rear Deck: No 6x9's just holes and grills
  3. #123
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    I wouldn't use ANY less than a 200-amp alternator, a primary battery, and a Powermaster D3100. I would suggest two D3100s.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
  4. #124
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,097
    66 Post(s)
    2 Thread(s)
    4958 Post(s)
    Re: Saz-3500
    Quote Originally Posted by Derrick824 View Post
    I got a little testing done. These are "unofficial" results. Until I use Jacob's equipment I won't consider it official. I did not use peak hold on my meters (and yes they are true rms). Instead I recorded my 3 meters all in real time with my camera reading ac voltage output, ac amperage output, and dc voltage input at the amplifier. Then I slowly rolled into the volume to prevent spikes and held it for 5 seconds so the readings could level off.
    Results:
    2,318watts @ 2.9ohms after rise @ 13.7v after drop.
    4,040watts right around 1ohm after rise dropping to 11.3 volts.
    Again, these were not peak hold measurements and these are unofficial results. I'll get some official results from Jacob's equipment on Monday or Tuesday. That way all our testing will be uniform from the same meters.
    sounds about right... getting a mean between the rest voltage and lowest voltage, i would say the amp will easly do rms spec very linear @12.5 volts... must sell my 1750 to get one of these.
    Insidious Audio
  5. #125
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    Results:
    In SPL Derrick was 1 dB up at 1 ohm vs. the 3000D!
    We got similar numbers on my clamp at the shop:
    3980 @ 0.25 rising to 0.65 @ 11.2v (engine on)
    2050 @ 1 rising to 2.44 @ 12.2v (engine off)
    These are measured ~6-10 seconds in as my meter takes some time to put up a reading - it does power all at once.
    - Jacob Fuller
  6. #126
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    Raymond Farmer's 12v Testing:
    "Okay, I have done my SAZ3000D 12volt power test. I would like to say, WOW!!
    My nominal ohm load was 0.5 ohms. I did plenty of test but I got the amp to do its power at the proper settings and did 3 test and took the average.
    I used 2 x NSB-g3100 to power the amp, Starting voltage 13.2
    Test 1
    75.1 volts
    39.9 amps
    2996.5
    box rise 1.88
    voltage drop 12.2
    Test 2
    75.1 volts
    37.7 amps
    2827.5 watts
    box rise 1.99
    voltage drop 12.1
    Test 3
    76.0 volts
    39.5 amps
    3002.0 watts
    box rise 1.9
    voltage drop 12.1
    Average of 3 test
    75.4 volts
    39.03 amps
    2942.86 watts
    box rise 1.92 approximately 2 ohms
    So 2942.86 watts @ 2ohms @ 12.1 volts
    That is some power!!!"
    Above quoted from Ray on our SSA forum :
    http://www.soundsolutionsaudio.com/f...howtopic=28412
    - Jacob Fuller
  7. #127
    mcsoul's Avatar
    Mar 2008
    dfw
    4,427
    Re: Saz-3500
    Silly question here, has anyone done 4 ohm nominal testing?
  8. #128
    Dec 2006
    New orleans LA
    32
    12,097
    66 Post(s)
    2 Thread(s)
    4958 Post(s)
    Re: Saz-3500
    what meter you have J?? im thinking about getting the B&K clamp/power meter measures VA VAR HP etc.. thing that go me thinking is the 3% tolerance... when your tring to troubleshoot i rathere have fluke but there near 2Gs!!
    feed back on the meter please.. i know the amp kicks ***,lol
    Insidious Audio
  9. #129
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    Quote Originally Posted by papermaker View Post
    I have an Extech unit - it will read VAR, VA, and HP as well
    http://www.extech.com/instrument/pro...99/380976.html
    I have had great luck with it.
    - Jacob Fuller
  10. #130
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    Quote Originally Posted by mcsoul View Post
    Nope - but I'd say it wouldn't be very impressive with a typical rise to 6-8 ohms or so! I don't really recommend running these big high current Class-D amps at 4 ohms as they generally don't perform very well.
    - Jacob Fuller
  11. #131
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Saz-3500
    I did some more testing recently :
    POWER : 3660 Watts
    AMP VOLTAGE (measured) : 65.84 V
    AMP CURRENT (calculated) : 55.58 A
    ACTUAL IMPEDANCE (calculated) : 1.18 ohms
    SUPPLY VOLTAGE : 11.9 V
    http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2510.MOV
    * Power Clamp
    http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2511.MOV
    * Voltage Measurement
    This was part of a larger group of testing :
    http://www.stevemeadedesigns.com/boa...howtopic=50753
    On that note... these are about to be back in stock in a few weeks.
    - Jacob Fuller
