how to bridge a 2 channel amp
Hello everyone, sorry if this has already been covered but I couldn't find the answer anywhere
I have a Power Acoustik 1600 watt 2 channel Amplifier, here is an example of the what the amp looks like
http://cgi.ebay.com/1600W-POWER-ACOUSTIK-OV2-1600-2Ch-Car-Amplifier-Amp_W0QQitemZ230312254008QQcmdZViewItemQQptZCar_Am plifiers?hash=item230312254008&_trksid=p3286.c0.m1 4&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:0 |293:2|294:50
RMS Power (4 ohms): 310 watts x 2 channel
RMS Power (2 ohms): 370 watts x 2 channel
2ohm stable stereo
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 4 ohms
I have 2 Sony Xplod SVC 4ohm subwoofers that I want to hook up. Does any one have a wiring diagram on how to bridge this type of setup?
Thanks
Re: how to bridge a 2 channel amp
You are either going to need to run the amp bridged with the two woofers in series, which will only be 8 ohms , or run the subs in stereo.
Is this the diagram you were reffering to?
Is it ok if the amp is 4ohm stable? Will I getting the most power to the subs this way?
Thanks again
Yes it is.
The power you'll likely end up with is the same power in mono @ 8ohms as
you would get at 4oms stereo.
Thanks...just wanted to make sure that this was the best way to get the most out of these subs
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
