Results 1 to 7 of 7
Reload Thread: need some advice on what amp to use
    Greggk's Avatar
    Greggk is offline An ARMY NCO 24/7
    Jan 2009
    Ludowici, GA
    338
    3 Post(s)
    9 Post(s)
    that will properly power and not kill my sub.
    i have a diamond audio D312 dual 4ohm, which i am going to wire to 2ohm.. here are the specs on the sub. btw i am only running the single 12" diamond audio D312 sub in a 1.0 cu ft sealed box
    http://www.diamondaudio.com/content/view/134/148/
    D312.2 - 12" Dual Voice Coil Subwoofer
    Textured Copolymer Cone with Aluminum Dust Cap
    Nitrile Butadine Rubber (NBR) Surround
    Heavy Gauge Stamped Steel Basket
    Integrated Tinsel Leads
    Venturi Vented Basket
    Vented Pole Piece
    Double Stacked Ferrite Magnet
    Optimized Spider with Balanced Linear Suspension
    2.5” Voice Coils Power Handling NOM/MAX: 400/800 Watts Sensitivity (2.83V/1m):
    86 dB SPL Freq. Response: 25-250 Hz Mounting Depth:
    6.2 in. Diameter:
    11.1 in.
    PaulThompson229's Avatar
    PaulThompson229 is offline Professional Mooch
    Dec 2008
    So. MD
    28
    2,315
    Re: need some advice on what amp to use
    Kicker ZX-500.1 should do nicely
    I would be a procrastinator, but I keep putting it off.
    My feedback Thread
    http://www.caraudio.com/forum/showth...28#post5684528
    Greggk's Avatar
    Jan 2009
    Ludowici, GA
    338
    3 Post(s)
    9 Post(s)
    any other suggestions?
    C3 Customs's Avatar
    C3 Customs is offline New Era in integrated SQ
    Sep 2008
    Baytown
    1,095
    Stetsom 1k6 2 ohm version
    SSL STA120
    Audiopipe 15001D
    SPL Dk2000D
    Mobile Spec ICEX-1000D
    O2 Audio Spiral 1.2KW
    more options
    [CENTER]"The mind is everything. What you think you become." - Buddha
    Bravox Audio - DLS - Stetsom - GermanMAESTRO- Second Skin -Arc Audio
    ref:mcsoul, rollerdj, 5o4m6, slam, Fiercetimbo17, Jerry B, t00sh0rt, hey, SavageBlackout
    Greggk's Avatar
    Jan 2009
    Ludowici, GA
    338
    3 Post(s)
    9 Post(s)
    thanks anymore suggestions?
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    BushJ311's Avatar
    BushJ311 is offline CarAudio.com Veteran
    Feb 2008
    NW, PA
    7,443
    15 Post(s)
    My crossfire will work good on the sub and leave you room to upgrade later
