Results 1 to 10 of 10
Reload Thread: 1200.1 The SUB killer
    drasik's Avatar
    drasik is offline Senior VIP Member
    Jul 2002
    T.O.
    157
    JBL 1200.1 - 4
    Sun Woofers - 0
    Okay my JBL 1200.1 has killed yeat another sub woofer.
    After going through
    Two 12L74's, Two 15 w3's(at the same time) and now the latest victum a modded 15 RE SE, It has officially been dubbed the sub killer. I was running the amp into a 1 ohm load and feed the SE it's last breath of air. Although only one coil went on the sub so it may live to see another day.
    Whats am I going to do with this amp, it has never clipped on me and continually destroys every sub I get. What should I do I love the power what sub could handle it especially the way I drive my subs???!!!
    DrasiK
    Blazin Civic's Avatar
    Blazin Civic is offline I got more bass than you
    Jul 2003
    Earth
    122
    Re: 1200.1 The SUB killer
    SoloX will handle it, just about any sub with a 1200 watt rms+ rating will handle it. Just get yourself a crossover with a subsonic filter.
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,485
    maybe an xxx can handle it. u sure ur box might not of been the problem?
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    35
    27,838
    15
    72 Post(s)
    CMPX2
    H2
    IDMAX
    the list goes on
    CarAudio.com mod(original)
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,572
    Are/were you using a subsonic filter if you were using a ported box? Volume/gain master also comes to mind. 1200.1's do funny things sometimes.
    I agree with denim's suggestions ... also wanted to tack on the aforementioned XXX.
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    xjmadness's Avatar
    xjmadness is offline The beauty of green
    Dec 2002
    ATL
    1,708
    wth......you don't have the gain at full tilt do you? i bet ur clipping the hell outa the signal
    anaranchi's Avatar
    anaranchi is offline your mom's hot
    Aug 2003
    tulsa,ok
    29
    2,503
    Re: Re: 1200.1 The SUB killer
    try this on for size
    18-Inch 10,000Watts Subwoofer
    Kicker SoloX 03S18X
    * Size (in., cm) : 18, 45.7
    * Impedance (Ohms DVC) : 1, 2
    * Max Rec Amplifier Power (watts peak) : 10,000
    * Max Rec Amp Power (watts RMS) : 5,000
    * Sensitivity (dB 1w/1m) : 89.7
    * Frequency Response (Hz) : 18-100
    * Mounting Depth (in., cm) : 11-3/8, 28.9
    * Mounting Cutout (square) (in., cm) : 16-11/16, 42.4
    ss3079's Avatar
    Mar 2002
    Up North
    22,572
    I'd be tempted to run way more than 1300 watts to one of those guys ...
    - Steve
    Moderator
    2007 Chrysler 300C
  9. #9
    somekook's Avatar
    somekook is offline only 15"s
    Jul 2003
    Daytona Beach, FL
    25
    1,178
    fuse your next sub between the amp and the sub..... so if it sends to much wattage to the sub the fuse will blow...not the sub
  10. #10
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    26
    5,170
    I run my JBL 1200 to my SE's..the handle it prefectly fine.. i bet u had ur gain cranked up or were u using that **** Bass boost....that bass booost is a sub killer for ya
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
  1. cheapest uve seen jbl 1200.1?
    By d audio 450 in forum Amplifiers
    Last Post: 08-28-2003, 04:09 PM
  2. SUB Killer
    By drasik in forum Subwoofers
    Last Post: 08-11-2003, 04:42 PM
  3. kicker 1200.1 + 2 pcs 10w7's
    By centrino in forum Subwoofers
    Last Post: 08-07-2003, 12:47 PM
  4. is this amp worth buying in place of a jbl 1200.1
    By phazeone in forum Amplifiers
    Last Post: 08-02-2003, 06:59 PM
