Results 1 to 12 of 12
Reload Thread: 4 GA. on 1500d ?
    Peaks's Avatar
    Peaks is offline Sir Bumpsalot
    Mar 2007
    Two Zero Seven
    37
    336
    4 GA. on 1500d ?
    I was thinking of putting my sundown 1500 in my winter beater for a while.I have a spare 13' 4 ga. power wire that I could use.Instead of handing out more money for 0/1 ga. wire,would the amp be safe if I ran it at 2 ohm's with the 4 ga.wire?
    Sold to Tez4life,Willywonka,Dwancha,andytb,2000LaDe,Second 2none,Woofercooker, portlandme
    Bought from Ionsql,The Cube,nate2587
    NewAgeKing's Avatar
    NewAgeKing is offline OG, still fly.
    Feb 2008
    Michigan
    5,093
    Re: 4 GA. on 1500d ?
    Yes. I ran my 20.1 at full tilt on a single 4g run. About 1800-1900 watts.
    tez4life's Avatar
    tez4life is offline Premium Member tez4life is a Supporting Member of the forum!
    Nov 2006
    Mobile, Al
    3,937
    9 Post(s)
    Will work fine, I ran 4 gauge, (all I had at the time) on my 1500d when I had it, but I never took the amp below 2 ohm, (had a single D4 15" wired in parallel).
    Amp worked perfect off that power wire, and it was old as hell lol.
    Refs and feedback (pre Itrader) on here http://www.caraudio.com/forums/buyer-seller-feedback/348682-tez4life-refs-feedback-thread.html
    Caraudioclassifieds.org feedback http://www.caraudioclassifieds.org/forum/members/tez4life/
    Ebay feedback http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=tez4life&ftab=A llFeedback
    gunz4me's Avatar
    gunz4me is offline Goodbye!
    Jul 2008
    Louisiana
    45
    2,218
    I would say you should be fine. My younger cousin is running a MTX 81000d @ 3 ohms to a 13w7 and he only used 4 gauge wire.
    Goodbye pudknockers.
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,859
    4 Post(s)
    644 Post(s)
    the MTX has 1/0 inputs for a reason
    thats way more than 1k
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
    x2o's Avatar
    x2o
    x2o is offline Fuzzy Blue Lights
    Nov 2007
    Miami/PSL, FL
    3,714
    You should be more then fine with 4 gauge on that amp, especially at 2ohms. Your gonna be looking at 1kw or so, which 4 Gauge should take fine. .
    The System :
    Electrical: Big 3, Powermaster D1200 and D3100.
    Sub Stage : 18" Custom Sundown Nightshade D2 Tuned to 30 Hz
    Sub Amp : Sundown SAZ-3000D
    Headunit : Alpine 9887 (ACTIVE )
    Front Stage : (2) Eminence Delta 10" mids, 2 Power Acoustik NX-5s
    Rear Pro Audio: (4) 8" Selenium 8W4P, (2) Selenium ST350
    Pro Audio Amps: Hifonics ZXi6010, Hifonics ZXi1010, Kicker ZX350.4
    Wiring : Kicker Hyperflex/Knu 0ga/RCA's
    Refs : Apocalypse Boy, Brian Owens, JBLCamry, ABSOLUTEAUDIO, BushJ311, tEh koRnDog(x2), blackbonnie, ProjectPat06, ampjunkielikeme, DownSouth954, Tapout, PaulThompson229, Mrogowski, Team H&K (Kent), andrewmoore13, slam, 100% eBay
    Peaks's Avatar
    Mar 2007
    Two Zero Seven
    37
    336
    If I decided to run at 1 ohm,do you think I would be asking for trouble?
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,859
    4 Post(s)
    644 Post(s)
    what does it put out at 1?
    what does your electrical look like. PERSONALLY, 1k+ i would use 1/0. i like overhead room
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  9. #9
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    So long as the power wire is fused right you'll have no issues...not to mention running it at 2ohms, you'll have a very hard time popping a 120amp fuse.
    2,500+ designs since March 2011
  10. #10
    Peaks's Avatar
    Mar 2007
    Two Zero Seven
    37
    336
    I would say around 1600 @ 1 ohm.It would be on stock electrical,but with a truck alt.
  11. #11
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,859
    4 Post(s)
    644 Post(s)
    i'd stick with 2 ohms if you only have 4ga
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  12. #12
    gunz4me's Avatar
    Jul 2008
    Louisiana
    45
    2,218
    Quote Originally Posted by jco1385 View Post
    I know... I told him to use 1/0 and he said "I don't feel like running another wire!"
    Then he proceeds to drop off a box full of Knukonceptz 1/0 along with some generic 8 and 10 gauge wire to my house
