Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: amps draining a batterY?
    joshpoints's Avatar
    joshpoints is offline CarAudio.com Veteran
    Jan 2003
    San Ma Tonga Central, CA
    34
    3,165
    1 Post(s)
    I have a factory size battery and I got up and it was dead today in the morning. I have a total of 1000 watts rms worth of amps in it and I just installed an alarm. I was wondering if all these new accessories discharge the battery even when the car is off and the amp aren't really on. I know this happened in my last car when I would hook an amp up that was rated at 300 rms in it and let it sit for a few days but it has a tired battery. Does it sound like my battery is done or like something else? Also yesterday I noticed that the car was a little slow to turn over, but didn't think too much of it.
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    Quote Originally Posted by joshpoints
    Okay I just did some calculations. I hav a sub amp that rms 600 watts so I figure it peaks at 800. I have another amp for my other speakers that is 400 rms and I figure 600 peak. This totals 1400 watts. I believe my factory alternator puts out 70 amps. That equals 840 watts. That leaves 560 watts that the battery is getting ****** out, or 46 amps ****** out. So I figure that maybe 5 days of this coupled with the alarm sucking juice from the battery at night caused it to go dead. Let me know what you think of this theory.
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    I understand your calculations, but it really doesn't work that way. If the battery was supplying current constantly your lights would dim terribly at night.
    More likely there's a constant draw on the battery when the engine's off. I'd suspect the alarm if it's new.
    If you have a DMM with a 10 amp DC scale, you can put the meter in series with the battery cable and check to see if there's constant current being drawn (arm the alarm too). Any more than a few milliamps means there's a problem.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    Quote Originally Posted by maylar
    That's a great idea I'll have to try it. Do amps draw any current when they are off? Do larger amps draw more current from the battery when they are off? To be honest I've never used this feature on my DMM. Where do I connect the negative wire from the tester?
    djjdnap's Avatar
    djjdnap is offline FreakyFreaks ofall Freaks
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    no an amp doesn't take energy when it's off... unless ur remote is also hooked up to ur battery or somthin that stays on....that way ur amp would always be on ...check that...
    KArAudio.COM
    OMGROFLHI2ULOLLERZTITSHAHAHAHASEALEDMTWTFSTFUKTHXB YENO0B
    -Nick
    GF7PE's Avatar
    GF7PE is offline Member
    Jul 2003
    cape cod
    42
    38
    also...you can upgrade the wire from the amp to the battery to a larger size. This will help transfer power to your system more efficiently. I have seen this happen when power somewhere is going to ground. Check for voltage at your ground
    nick3470's Avatar
    nick3470 is offline Ballin' on a Budget
    Jul 2002
    Ames, IA
    686
    Quote Originally Posted by djjdnap
    thats happened to me before, when i finished putting my amp in i left some wire sitting in the trunk, and the positive on the amp ended up keeping the remote turned on (freak wire mishap)
    abcdefg's Avatar
    abcdefg is offline CarAudio.com Veteran
    Oct 2002
    Clarksville, Tn
    31
    2,330
    just check and see when u turn ur car off if the power light on the amp stays on
    Pioneer Premier DEH-660
    1 12inch ED k
    2 12inch RE HC's
    Hifonics brutus 1000d
    infinity kappa 6 1/2 components
    polk 5 1/4's
    US Acoustics USX2080
    sony cd player-4sale
    jensen 4's- 4sale
    check this out guys:
    http://www.sounddomain.com/id/tumultgoboomboom
    Aim= wrde2005
    Email= [email protected]
    Aol instant message= wrde333
  9. #9
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    Quote Originally Posted by GF7PE
    I'm currently using 0 gauge power wire. When you say test your voltage at your ground do you mean at the ground bolt for the amp?
  10. #10
    GF7PE's Avatar
    Jul 2003
    cape cod
    42
    38
    Check there and in a few random locations....may be something else causing the leak
  11. #11
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Amps should draw near zero current when they're off. If you want to use your meter to check things out:
    Shut off all electrical things and close the doors. Also remove any capacitors you might have in your audio system.
    Then remove the negative battery cable and put the ammeter in series with the cable and the battery post (meter + to the cable, meter - to the battery terminal). Note that you'll probably get sparks at first because the caps in your amplifiers have to charge, but that only lasts an instant.
    If there's something drawing current, it'll show up on the meter. In order to drain the battery overnight, it'll be significant current (more than 1/10 amp). You'll normally get only a few milliamps drain from the clock and such.
    Start removing fuses from your car's fusebox until the current draw goes away, then track down whatever is on that circuit. Normal suspects are lights that can be on without you knowing (trunk, glovebox, etc), or a frayed wire touching ground. Or a "partially on" brake light switch.
    If you get all the fuses out and there's still current being drawn, take the red wire off the alternator. Leaky or defective diodes in your alternator will drain the battery nicely.
    dave
  12. #12
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    Okay I just fried my dmm last night trying this. Let me make sure if I'm understanding you correctly. Last night I left both terminals connected at the battery. YOu're saying I should just leave the positive cable connected on the battery, hook my positive on the tester at the positive battery terminal and then disconnect the negative battery cable and connect my negative battery tester to the negative terminal on the battery? Let me know if this is right or wrong, I don't want to fry another one.
  13. #13
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    LOL, yea dude. An ammeter goes in SERIES with the circuit to measure the current flowing through it. A voltmeter goes ACROSS the circuit (parallel). Usually there's a fuse in a DMM to protect against accidents like you had. Check inside before buying a new one.
    dave
  14. #14
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    Too late I already bought a new one. It has one terminal that is fused and one that is not. THe fused one can only read up to 400 ma. THe unfused one can read up to 10Amps.
  15. #15
    joshpoints's Avatar
    Jan 2003
    34
    3,165
    1 Post(s)
    I tried it hooking it up with just the positive cable connected at the battery and the alarm didn't turn on and I didn't get a power reading.
  1. how to wire up my amps?
    By RFmustang in forum Wiring, Electrical and Installation Help
    Last Post: 10-03-2004, 02:22 PM
  2. us amps Q's
    By buthatsabuick in forum Amplifiers
    Last Post: 03-06-2004, 01:33 PM
  3. new jbl amps woww
    By abcdefg in forum Amplifiers
    Last Post: 08-01-2003, 01:27 AM
  4. optima yellow top aux. battery?
    By cobra65427289 in forum General Discussion
    Last Post: 07-26-2003, 08:24 PM
  5. wire size..... 2 amps
    By er1kkull in forum Wiring, Electrical and Installation Help
    Last Post: 07-20-2003, 01:34 PM
