Results 1 to 3 of 3
Reload Thread: jbl 180.2 problem, dont know what's going on
    zephyr's Avatar
    zephyr is offline Senior VIP Member
    Jun 2003
    here
    179
    Icon32 jbl 180.2 problem, dont know what's going on
    i got this problem since the remote wire touched the HU's chasis while everything is on. the amp sometimes work just fine but sometimes shut off after a couple minutes of play. after it shut off i can't get it on for a while. before shut off the red led turn for a second. i thought it was overheated but i tried it at night and the same thing happened. i've tried switching the power wire with my alpine too. anybody ever has a problem like this?
    Denon - PPI - JL Audio- Image Dynamics - CDT Audio - Hugfen
    djjdnap's Avatar
    djjdnap is offline FreakyFreaks ofall Freaks
    Mar 2002
    indy-nap-lis
    1,971
    yea u might have burn somethin in the amp because my old amp(now dead) use to cut off but i think it was because i was running to low of an impedence... I had to hit it a few times to make it work, took it apart, tested a few points, then came across this little black section, , my friend has an amp that he bought and it was the same, so i might get them fixed, idk..
    those are my thoughts
    KArAudio.COM
    OMGROFLHI2ULOLLERZTITSHAHAHAHASEALEDMTWTFSTFUKTHXB YENO0B
    -Nick
    zephyr's Avatar
    Jun 2003
    here
    179
    the amp is fine now, it was a bad fuse that cause it to shut off.
