Results 1 to 13 of 13
Reload Thread: Remote turn on Wire
    namster44's Avatar
    namster44 is offline Great White North
    May 2002
    Canada
    646
    Remote turn on Wire
    I got a two amps, and I was wondering if I really need two remote turn on wires...aka one for each amp. Could I just wire one, and then have another shorter wire run from one amp to the other? One amp is for the subs, and the other for comps...how could I make a switch for the sub amp while still running the comp amp?
    This years line up.....
    *eD, Tsunami, CDT, Alpine, EFX wiring/block/fuses*
    Aurorav8's Avatar
    Aurorav8 is offline CarAudio.com Elite
    Apr 2003
    Fort Wayne
    39
    1,610
    Yeah, you can just run a shorter remote wire from one amp to the other.
    namster44's Avatar
    May 2002
    Canada
    646
    figured so, but I still need to find a way to work the comp amp without the sub amp working, maybe this will work....
    HU
    | <---remote wire
    [spilter]
    [Switch] |
    [sub amp] [comp amp]
    wonder what radio shack has got in stock....
    Aurorav8's Avatar
    Apr 2003
    Fort Wayne
    39
    1,610
    A switch should work, but why wouldn't you want your sub amp working?
    DaBaller504's Avatar
    DaBaller504 is offline Livin Loud In Da Blazer
    Oct 2002
    Westover, Pa
    32
    998
    yah
    Why wouldn't you want it turned on????
    1995 Chevy Silverado, K1500 With 350 Cubic Inches of Raw Power.
    namster44's Avatar
    May 2002
    Canada
    646
    Basically so I can have control so I can bump responsibly and stuff. I will be running a pair of eD 15As, so I imagine they will get freaking loud and sometimes it's not a good idea to be running around will all that bass. Hopefully...hopefully my CDT comps and mid bass drivers in the rear will be enough to hold me over when the subs are hammering away.
    namster44's Avatar
    May 2002
    Canada
    646
    Edit : "aren't hammering away...." not are
    Oct 2002
    Westover, Pa
    32
    998
    ok
    I see what your looking for. Just keep the volume down. A lil bass and still have that is evened out with your mids and highs.
  9. #9
    burtonsnow83's Avatar
    burtonsnow83 is offline shred the gnar
    Jan 2003
    Salt Lake city Ut
    34
    535
    HU
    | <---remote wire
    [spilter]
    [Switch] |
    where are you getting the switch?
    http://www.sounddomain.com/id/burtonsnow83
    148.1 on the dash(rangerman's mic)
    H/U -Alpine cda-9815
    Comps- CDT Cl61a
    Sub- 2 edk 12.44
    amps- Avionixx AXT 800.2
    Us acoustics usx2080
    box - 2 cubes each at 33 hz
    wiring-knukonceptz
    All in an 02 xterra
  10. #10
    namster44's Avatar
    May 2002
    Canada
    646
    just some place that sells all sorts of these switches, DIY electronic parts/kits...crap like that
  11. #11
    Rockman's Avatar
    Rockman is offline CarAudio.com Elite
    Nov 2002
    topeka
    518
    Why not just use the subwoofer level control in your HU? It does have one doesn't it???
    Car 99 Toyota Solara SLE V6
    HU Clarion DXZ835MP
    Front Speakers Infinity 6 1/2 Kappas
    Front Amp Crutchfield CR4X50
    Subs Kicker 12L7's
    Harrison Fmods
    Sub Amp PPI PC 2600's
  12. #12
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    After listenign to systems with subs, I dont' think the switch will EVER come into play after two tries.
    I also don't think your components will give you the bass you require even at reaonsable levels, if the xover points are correct. You don't hear anything below 80 or 100Hz (your sub's low pass point)
    TO boom responsibly, keep volume down and use plenty of dmaping materials to try and keep noise confined in the cabin,
    As rockman says, use your hu to lower the volume of your subs if need be.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
  13. #13
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    I have a switch wired on my opti 1000.1D remote so I can switch it off and still use my 200.2.
    Why?
    Because I listen to a lot of sports talk on AM radio and the class D circuitry causes a TON of interference. With my sub amp on I can't pick up a thing, switch it off and I get crystal clear reception.
