Results 1 to 7 of 7
Reload Thread: Help on wiring...bridging...easy question!
    jmass03's Avatar
    jmass03 is offline Member
    Oct 2004
    FL
    136
    I have two pairs of speakers. Two speakers in one can on one side. Another two speakers in one can on another side. Each can needs around 400 watts or so at 4 ohms.
    I also have a Kicker ZX850.4. Specs are: http://www.woofersetc.com/index.cfm?...roduct_ID=3959
    Basically bridged that amp can put out 425 by 2 channels. I'm looking at the amp right now. On the side of the amp it says AMP 1 and AMP 2 for the speaker connections. Under AMP 1 it gives me L+ and L- then R+ and R-. To the right of that is AMP 2 and that also gives a L+ and L- and then a R+ and R-.
    In between that it says BRIDGE WIRING and thats L+ and R -.
    I have 4 speaker wires. Two positives and two negatives. Where do I put them?
    DidUHearThat?'s Avatar
    DidUHearThat? is offline Precious Bodily Fluids
    Jul 2008
    General Ripper, Base Commander
    2,197
    Re: Help on wiring...bridging...easy question!
    If each speaker is 4 ohms, then you can not bridge two together as a 2 ohm load. You can only bridge into a 4 ohm load.
    Rockford/Denon 8250
    Hifonics NX880
    Alpine MPR450
    CDT CL61-IEK
    CDT 6X
    Elemental Designs 11kv.2
    KnuKonceptz
    Optima Yellow and Red Top
    130 Amp alternator
    jmass03's Avatar
    Oct 2004
    FL
    136
    yes I know, each speaker is not. Each can is loaded to 4 ohms.
    Can #1 = Purple (+) Purple (-). Does this go to AMP 1? As per the amp instructions L+ and R-?
    Can #2 = Green (+) Green (-). Does this go to AMP 2? As per the amp instructions L+ and R-?
    So basically 8 terminals devided into 2 pairs of 4.
    On the first pair of 4 speaker terminals you have AMP 1
    On the second pair of 4 speaker terminals you have AMP 2.
    (I'm trying to make this as easy as possible to visualize).
    Step BY step:
    You take the (+) from Can 1 and put that into L (+) under AMP 1. Then take the (-) from Can 1 and put that into the R(-) still under AMP 1.
    Then you take the (+) from Can 2 and put that under L (+) under AMP 2. Then take the (-) from Can 2 and that under the r(-) under AMP 2.
    Correct?
    jmass03's Avatar
    Oct 2004
    FL
    136
    This is exactly what I did. Just imagine where it says "SUBS" substitute it with "Speaker Cans." Did I do it right?
    azimuth's Avatar
    azimuth is offline funded*by*soros
    Mar 2006
    Denver, Co
    41
    9,053
    9 Post(s)
    looks right. so you have 8 ohm speakers in the doors?
    2003 chevy s-10 ext. cab
    hu: jvc kd-avx1
    precision power 356cs components
    front amp: infinity 475a
    sub: diamond audio d6 10d4
    enclosure: 1.1 cubes ported tuned @ 31hz
    sub amp: JL G1700
    fbi90909's Avatar
    fbi90909 is offline Panty Thief
    Jun 2006
    Key West, FL
    35
    7,768
    4 Post(s)
    Quote Originally Posted by jmass03 View Post
    that seems about right.
    you want to tell us exactly what speakers your running?
    i will not put **** or outside links in my signature again. if i do i will be banned. all hail the moderators.
    LDW3RD's Avatar
    LDW3RD is offline CarAudio.com Elite
    Jun 2003
    PHILLY
    47
    1,293
    8 Post(s)
    What exactly are you asking b/c it seems straight forward with what you have to do.
    All reggae all the time.....
