Results 1 to 8 of 8
Reload Thread: Alpine MRD-M300 setup Question
    demomike1's Avatar
    demomike1 is offline Junior Member
    Jun 2003
    Boston,MA
    19
    Trying to set my M300 to reach full power at an earlier stage. I can't seem to get the clipping/over LED to light up with the SUBW level set to 0 on the HU (Alpine 9805). Anyone know how to "force" the amp to put out max power at a particular volume? I don't want to have to put the volume to max to get max power from the amp. Hope this makes sense (should to anyone that owns the M300/M500). Thanks
    Terminator's Avatar
    Terminator is offline Member
    Apr 2003
    San Angelo, Texas
    137
    i dont think it will unless you turn the volume way up. but i could be wrong. maybe if you wire the subs down to 1.5-2 ohm.
    *'95 Del Sol VTEC
    -To do List:-
    HU- Alpine CDA-9813 - Installed
    Front- Alpine Type-R 6.5" - Pending
    Rear- Alpine Type-R 6.5" - Pending
    Sub- 12" Rockford HX2 - Installed
    Amp- Rockford 301M or 501BD - Pending
    Wireing- Stinger 4 AWG - Intalled
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    33
    5,152
    increase the gain.
    MSN - [email protected]
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
    demomike1's Avatar
    Jun 2003
    Boston,MA
    19
    I have an SWR-1241D wired to 2ohm.
    There is no gain on this amp. It's digital. There is an input voltage selecter, that's it. My HU has a 4v preout so I set the amp to -18db(4v).
    Feb 2002
    Vancouver BC
    33
    5,152
    input voltage is gain.
    turn that up higher if you want to clip your amp...
    or want to force it to produce more power...
    demomike1's Avatar
    Jun 2003
    Boston,MA
    19
    It won't hurt the amp if I set it to say -6db (1.0v) even though I have 4v preouts? This DOES make it louder but I don't want to cook anything.
    Feb 2002
    Vancouver BC
    33
    5,152
    it iwll increase the likelyhood of clipping...
    it will allow your amp to put out more power at a lower volume...
    if you aren't careful, it can hurt your amp... but also you sub...
    just turn it u pa little bit... until you get that clipping indication at a volume above where you would normally listen.
    demomike1's Avatar
    Jun 2003
    Boston,MA
    19
    OK,I'll give it a go. Thanks for the help.
