Results 1 to 5 of 5
Reload Thread: 4 channel amp question, sub output
    outbacksport's Avatar
    outbacksport is offline Senior VIP Member
    May 2003
    S Cal
    309
    I got the US Acoustic 4065 4 channel amp, and an alpine 9813 with 3 preouts.
    I know the front rca cables goes to the 1/2 channel, can i connect the sub output
    cable (instead of the rear output cable) to the 3/4 channel for my subs? Im not
    really sure if the sub output works with a 4 channel amp.
    ActionJ-01-Z71's Avatar
    ActionJ-01-Z71 is offline Action Jackson
    Jan 2003
    TULSA
    42
    237
    14
    Yes. Either will work.
    AJ
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    Alpine Type R 12 4ohm DVC
    Kicker XS-100 @ 2 ohms
    BOOMER!!!!!
    May 2003
    S Cal
    309
    Just go my amp today, USB 4065, i opened the manual and it says it need atleast #12 speaker wire and i bought 16 gauge streetwires. Can i use that 16 g or should i buy
    the 12g?
    don's Avatar
    don
    don is offline Junior Member
    May 2003
    philippines
    40
    the 12g?
    Yes you can use it.
    May 2003
    S Cal
    309
    So why did the manual says at least #12 wire then?
