Results 1 to 15 of 15
Reload Thread: horrible distorting...
    Tek's Avatar
    Tek
    Tek is offline ...
    Nov 2002
    Palatine, IL
    32
    612
    Installed my amp yesterday to power my rear speakers, its a 40x2 rms to 50 rms speakers which were formerly powered by the headunit. It sounds nice with no bass, but when any low frequency gets played it distorts horribly, worse than before the amp. I've messed with the gains, and some headunit settings, what else should i check? bad connection somewhere? I expected lower distortion...not more. Please help.
    93 Oldsmobile Cutlass
    Headunit: Pioneer DEH 6400
    Speakers: JL Audio
    Subs: Elemental Designs 12" K
    Amps: Profile California 600
    Wiring: Scoshe/Phoenix Gold
    Encolsure: 1.5cf Ported Box tuned to 26 hz
    JaJay721's Avatar
    JaJay721 is offline Senior VIP Member
    May 2003
    NJ
    229
    What speakers and amp do you have? Sounds like you just have lower quality equipment. Try turning the bass all the way down and see if it still distorts. If it stops, turn it slowly and when hear some distortion, go back a few notches and leave it alone.
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    most speakers are not designed to play the lower freq. spectrum....most likly need to have a high pass filter set to block the low freq's if possible......
    Tek's Avatar
    Tek
    Tek is offline ...
    Nov 2002
    Palatine, IL
    32
    612
    Well, I'm using the sonys that are in my sig and the pioneer amp that is in my sig, they aren't great but they suffice untill June 1st But anyways, I know that those 6x9s aren't going to get sub-quality bass, but when I was powering them with my headunit, the bass was alot better than what it is now.
    Speakers: JL Audio
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    36
    8,477
    32
    The problem is that they're 6x9's....the oval design is conducive to distorting, especially when you push them to their limits. Your HU wasn't providing quite enough to power to make the distortion incredibly noticeable, but when you made the jump to 40 watts, that distortion becomes much louder and much worse. You should set an HPF on the speakers at around 80 or so, set your gains properly, and dont turn up the bass on your HU settings. That's about all you can do...but there's only so much you can do with 6x9's
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    Tek's Avatar
    Tek
    Tek is offline ...
    Nov 2002
    Palatine, IL
    32
    612
    hm...never thought of it like that gauntlet. The problem with that then would be i would be getting NO bass whatsoever, considering i only have 3.5"s in the front. Maybe i should just hook them back up to the headunit and wait till i get a sub.
    Speakers: JL Audio
    JaJay721's Avatar
    May 2003
    NJ
    229
    Just turn the gains down on the amp. Your amp can send cleaner power to the speakers than your head unit can.
    Tek's Avatar
    Tek
    Tek is offline ...
    Nov 2002
    Palatine, IL
    32
    612
    i've tried that, the only thing it seems to do is lower the volume of the speakers the amp is powering, it still distorts.
    Speakers: JL Audio
  9. #9
    Tek's Avatar
    Tek
    Tek is offline ...
    Nov 2002
    Palatine, IL
    32
    612
    i know they were the first thing i ever bought to upgrade my sound in the car, unfortunately it was also before i knew anything. i would upgrade, but im saving for a sub instead and after that i may take them out. or maybe buy some circular speakers and put em in the baskets.
    Speakers: JL Audio
  10. #10
    JaJay721's Avatar
    May 2003
    NJ
    229
    All 6x9 speakers don't distort. You can still have 6x9s if you want.. they can generally get louder and deeper than 6.5"s in the same price range. If you like the sound from a 6x9 don't not get them because your cheaper quality ones are prone to distort when you send em 40 watts.
  11. #11
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    36
    8,477
    32
    No. All 6x9 speakers will distort when they reach full excursion.
    - Slug
  12. #12
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    agreed......and as he said its due to the oval design.....they cant reproduce the freq. properly....
  13. #13
    BassRacer's Avatar
    BassRacer is offline Senior VIP Member
    Jan 2003
    Westside
    33
    270
    so i guess hexagon subs r ****** 2?
    1984 Olds Cutlass Ciera 2.8L 4 dr
    Windows Tinted Already
    Upcoming Mods:
    1)Custom Dual Exhaust from Midas w/ Chrome tips
    2)Dual Electric Cooling Fans (Spal or Flex-a-lite)
    3) K&N Air Filter System
    4) 16'' Rims
    5) Air ride Suspension
    Coming soon Summer of 2K3
    Hu-
    Alpine CDA-7995
    or
    Alpine CDA-9815
    Comps- Dunno yet
    Comp Amp(s)- Dunno yet
    Subs-
    2 12'' Elemental Designs A Series Subs Dual 2 ohm
    Sub Amp(s)- Dunno yet
  14. #14
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    subs are a bit of a diff. story.....but yes i velieve the hexagonal subs would have a tad bit more of a problem recreating the freq's than a round sub.....
  15. #15
    JaJay721's Avatar
    May 2003
    NJ
    229
    Almost all speakers will.. What I was saying is that if he likes the sound from a 6x9 he should not be repelled from them because his lower quality ones distort at his current listening levels. He will not have that problem if he has a better speaker.
