Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: Noob question about ohms
  1. #16
    Nova76's Avatar
    Nova76 is offline CarAudio.com Elite
    Feb 2008
    Tucson, AZ
    27
    782
    Re: Noob question about ohms
    no either .5ohm, 2ohm, or 8ohm unless you got another one you can run it at 1.34ohm i belive
    http://www.the12volt.com/caraudio/wo...s.asp~Q~2~I~22
    Car-1976 Chevy Nova
    Engine-350 HO sBc, Holly 650cfm, 1" wide open carm spacer, 470/470 Comp Cam, High Volume Oil Pump, double roller timing chain, Edelbrock RPM Air Gap Intake
    HU- Pioneer DEH-P2900MP
    Inside Speakers- (2)Kicker 6x9s rear (2)Clairion 6.5"s doors (1)Pioneer 4x6 dash
    Inside Amp-
    Sub Amp-1000.1D
    Wire- Lightning audio 2 gauge
    Subs- 12" Lightning Audio VC2 x2
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
    Traded With - Ravens9322
  2. #17
    3kracing's Avatar
    3kracing is offline Senior VIP Member
    Apr 2008
    USA
    272
    I've got two of the mojo subs. I just want to be able to give it the most power that I can.
  3. #18
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    27
    782
    well your amp wont run .5 ohm so you can only run them at 2ohm unless you get a bigger amp or another sub
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  4. #19
    3kracing's Avatar
    Apr 2008
    USA
    272
    Ok, what would be the best inexpensive amp to get? Or just get a 2nd VX2200D?
    Another sub is out of the question. I'm already running out of room with 2 subs.
  5. #20
    Nova76's Avatar
    Feb 2008
    Tucson, AZ
    27
    782
    either get another one because then you can run each sub at 1ohm off of 1 amp or sell the one you have and get one that can run a .5ohm or that can put out good porer at 2ohm
    Car-1976 Chevy Nova
    Inside Amp-
    Sub Amp-1000.1D
    Box- 2.5cf sealed
    REFS-
    Sold To - DBDRAGGUY
  6. #21
    3kracing's Avatar
    Apr 2008
    USA
    272
    Ok if I do get a 2nd amp can I run the 2nd amp of the same battery or would I have to get a 2nd battery?
  7. #22
    Van man's Avatar
    Van man is offline Man with the van
    Mar 2008
    mitchell, SD
    29
    you can bridge the amps.....i had 2 300 watt 1 channel amps in my stratus u can run the same power line from ur battery but get a differnt fuse block...
    it should look like this
    http://christmas.topshop.co.il/uniqu...ts/sml/423.jpg
    and from there run the line to ur amps one line per amp....hope that helps a bit
    Last edited by Van man; 04-19-2008 at 10:59 AM. Reason: screwed up with the website URL
  8. #23
    3kracing's Avatar
    Apr 2008
    USA
    272
    thanks that helps a lot!
  9. #24
    Van man's Avatar
    Mar 2008
    mitchell, SD
    29
    np
