Results 1 to 3 of 3
Reload Thread: 2 Kicker CVR and Xplod amp wiring
    dta1984's Avatar
    dta1984 is offline Junior Member
    Apr 2008
    Ohio
    Hey guys, first post here, so bare with me. I have done tons of searching and believe I have what I need, just want to confirm.
    I have 2 Kicker comp 12" CVR's (yellow and black series) and a 760 watt 2 channel Xplode amp. Here are the specs for the amp: 300 x 2 @4 ohms, 760 monaural @4 ohms. THis is not my first, or second choice of amp, it was a set that I bought so it will have to work for now.
    What is the ideal way to wire this to get the most out of the subs? Here is a link to what I am thinking:
    http://www.crutchfield.com/learningc...F2%2Dohm%5F2ch
    Is this ok, or is there a better way to do so? It appears that I need to wire it for 4 ohms, as it does not look to be 2 ohm stable. The amp is bridgable so I might do that. Thanks guys!
    2Kaccord's Avatar
    2Kaccord is offline CA.com Vet
    Apr 2008
    Oakland, CA
    228
    Re: 2 Kicker CVR and Xplod amp wiring
    wouldnt recommend bridging it, as sonys are not the most stable.
    -poor college student-
    diamond D3 1000.1
    kicker L7 15' tuned to 33hz
    Quote Originally Posted by Toasted1 View Post
    I have a friend at homeland security who has access to the Teleglobe GPV system and can take care of this for you. He only requires noods of your lady freind (with a bag over her head please) and he can track it down to within 100 yards of where the phone is located.
    Please hurry as he does have some other terrorist work **** to work on also tonight but is willing to do me this as a favor.
    PM box is open
    Quote Originally Posted by Randy Savage View Post
    Doesn't work for anyone else, n00bx cube.
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    What voice coils do the subs have? Dual 2 ohm or dual 4 ohm? If you have 2 dual 4 ohm subs, wire each sub in series to 8 ohms, and then wire them in parallel to the amp, bridged. This will present a 4 ohm mono load to the amp. If you have 2 dual 2 ohm subs, wire each sub in series to 4 ohms and run one on each channel, or bridge it at 8 ohms.
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
