Results 1 to 3 of 3
Reload Thread: Best amp for 2 600RMS subs
    Jun 2002
    Chicago,IL
    31
    603
    What would be the best amp to Power 2 12" RE SE's (600RMS each)??? Would you go with the JBL 1200.1? any amps with a subsonic filter that can power these and still stay under $300?
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    @ wat ohms can u run the subs at?
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    The subs are DVC 4-ohm so he can get the elemental designs nine.1 and run it at 1-ohm. It should crank out 1200 RMS @1-ohm since the website says it does 1009 @1-ohm with only 10.9 volts.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
