Results 1 to 14 of 14
Reload Thread: which setup is better?
    fresh's Avatar
    fresh is offline Member
    Apr 2003
    Vancouver, BC
    65
    Hey guys..
    I am thinking of buying a 10'' type-R sub and I am not going to change the factory deck or speakers (benz c220, decent sound).
    question: Is it better to run the sub off of a 2-ch amp mono, or off of a 4-ch amp (2 lines to the sub and 2 to the front component speakers)???
    In other words, will 2 lines off of a 4-ch amp be sufficient enough for a type-R sub?
    I am thinking of either a v-power alpine, or a rockford 500x or an 800A.
    Also, do you know of any place that sells amps cheap (and recommend the type of amp please)
    thank you
    fresh.
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    also what do you think about JL Audio 10" Subwoofer (10w6-AE) compared to the type-r
    thanks
    fresh.
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    especially if the jl 10'' is being pushed by a clarion APX201
    please somebody talk to me, coz there is a dude that is selling this combo (4 months old) and I am thinking of buying. He is asking $600 canadian (is that fair?)
    thanks a whole lot.
    fresh.
    jjoven1225's Avatar
    jjoven1225 is offline CarAudio.com Elite
    Nov 2002
    NJ
    30
    693
    i would take JL w6 or w6v2(even better) over type R, i heard type R myself, and not very impress with it.. about amps, if you want to get components, then yea go with 4 channel amp, but if you're not changing your speakers, just adding bass, just get a 2 channel or mono amp (cheaper).. to be in a safe side, just get a two channel, so if you do decide to get components, you can always run a two channel amp in a 3-way...
    ebay or thezeb.com is prolly the cheapest out there...
    as for your subs, have you consider eclipse titaniums???
    and amps, look into xtant, PG, soundstream, JL, or rockford...
    if i were you i would look something that would match my car...
    for example if your car is black i would get JL, if you car is white or silver, i would get eclipse.. that's just me tho..
    Lexus IS300
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,439
    the w6v2 is a pretty hard sub to beat if you push decent power to it ( maybe the jl 500/1). if i were doing this system and you like your factory speakers, i would definitly at least change the deck. a deck with a 5 volt preamp output will make your bass sound so much better. anyway, that is just my opinion, it is your car, do what you want with it.
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    would the Clarion APX201 be enough to run the jl sub?
    thanks
    fresh
    DaBaller504's Avatar
    DaBaller504 is offline Livin Loud In Da Blazer
    Oct 2002
    Westover, Pa
    27
    998
    jl
    get the jl with the 500/1
    definitely change your deck, better options, sound, and looks nicer
    1995 Chevy Silverado, K1500 With 350 Cubic Inches of Raw Power.
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    hey guys, if I do buy the jl 10w6AE then it has to go with the clarion APX201 because this is a used combo that someone is selling...
    Do you think it will work?
    Thanks
    fresh
  9. #9
    Randy Savage's Avatar
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    What are the specs on the amp?
    Ignore those telling you to get the 500/1, you probably won't tell a difference between teh 2 amps...
  10. #10
    Oct 2002
    Westover, Pa
    27
    998
    suggestion
    i was just giving a suggestion on the JL 500/1, its a good amp
  11. #11
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    2/1 CHANNEL POWER AMPLIFIER
    • NEW Heat Sink Design
    • Maximum Power Output 200W
    • Continuous Average Power Output 100W (50W x
    2 into 4 Ohms 20Hz-20kHz @0.05% THD)
    • Typical 2-Ohm Stereo 100W x 2 @ 0.5% THD
    • Typical Bridged Power 1kHz 230W @ 0.5% THD
    • Bass Extender Control 0~18dB @ 45Hz
    • Adjustable 55Hz - 5.5kHz, 12dB/oct. High/Low
    Pass Crossover
    • Mixed-Mode Operation
    • Bridgeable 2/1 Channel Operation
    • Speaker Level Inputs
    • Double-Sided Glass Epoxy Circuit Board
  12. #12
    fresh's Avatar
    Apr 2003
    Vancouver, BC
    65
    these specs are from the clarioncanada site.
  13. #13
    Oct 2002
    New York
    28
    21,083
    4 Post(s)
    230 watts bridged should be good for that sub...
  14. #14
    bri487's Avatar
    Feb 2003
    birth canal
    7,439
    i would give that sub between 300 and 350 watts.
